error message on login
Thread begun 4/19/2013 8:03 pm by cliftonr254050 | Last modified 4/22/2013 1:35 pm by cliftonr254050 | 887 views | 2 replies |
cliftonr254050
I am running powermessenger on my localhost testing server apache 2.2 PHP 5.3.1 and MySQL 5.1.43 it was setup ok until I try to logon as user I get this error and can’t go any farther.
Warning: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for '-4.0/DST' instead in C:\server\www\myserver.dev\public_html\PowerMessenger\webassist\themes\Default\images\installed.png on line 2
Please help
This is a configuration issue.
in the php.ini file, there is a setting for:
date.timezone
the error is saying this setting is left blank. In reality, this isn't an error, it's a warning. It's only showing because the error reporting level is set to show errors and warnings.
you will need to edit the php.ini file for the server to set the date.timezone setting.
cliftonr254050
