eCart checkout page not validating correctly
Thread begun 4/19/2013 9:55 am by info185511 | Last modified 4/19/2013 12:44 pm by Jason Byrnes | 1976 views | 5 replies |
info185511
Checkout wizard created a checkout page and confirm page, followed the video "Add server validation to your web forms". Followed the steps for the Billing Information and it worked fine, gave me notice where the required fields were left blank. Went back and did Shipping Information now if the Billing is filled out and the Shipping area is incomplete rather than a notice appearing as to where the required field is all the entries are lost both Billing and Shipping. As shown in the video I used Dreamweaver to add an additional value to each of the fields ( Initial Value). Could not find a similar problem . Please advise. John.
send a copy of your pages please.
info185511
Checkout and confirm files as well as related material
Not sure if you required all related to problem but have sent as stuffit file. Please let me know if anything else is required. Thanks in advance John
i am not able to open the sitx file you sent, please compress the files to a zip archive and send the zip file.
info185511
RE: Checkout and confirm files as well as related material
Attached is the material in a zip file Thanks again, John
on the confirm page, there are 2 server validation server behaviors. You should not have 2 instances of the server validation server behavior, there should be only 1 instance.
Open the server behaviors panel, in the list of server behaviors, delete the second one, then double click the first one to edit it and add the validations for the shipping.
