unterminated parenthetical
Thread begun 4/19/2013 9:47 am by chris369732 | Last modified 4/19/2013 11:18 am by chris369732 | 3976 views | 4 replies |
chris369732
When trying to edit one of my eCart objects, Dreamweaver throws a JavaScript error saying there is an undetermined parenthetical at line 686 of WA eCart Object.js that occurred while executing timer in WA eCart Object.htm. I am able to edit some of my other eCart objects, but this error appears on a few of them. I am not entirely sure why it works for some, but not others. Interestingly, when looking at the file the snippet in which the error occurs is labeled // hypothetically this code is no longer needed. Thank you.
since you don't get the error when editing some eCart objects, i would guess the problem is specify to the way the eCart objects that do have the problem are defined.
can you send a copy of one of the eCart object files that you are getting the error with.
chris369732
Thanks. The file is attached.
your hand coded function to recalcualte the rpice is causing the error.
function ResetCalculations($itmObj)     {
   $itmObj->Cost = (($itmObj->OIDStatusID > 7) AND ($itmObj->OIDStatusID < 10))?0:($itmObj->OIDStatusID == 7?(($_SESSION[PUROPOSID] > 2?abs($itmObj->OIDUnitCost):(($itmObj->UPDCQtyBreak2 > 1 AND $itmObj->Quantity >= $itmObj->UPDCQtyBreak2)?$itmObj->UPDCQty2Cost:(($itmObj->UPDCQtyBreak1 > 1 AND $itmObj->Quantity >= $itmObj->UPDCQtyBreak1)?$itmObj->UPDCQty1Cost:$itmObj->UPDCCost)))*-1):($_SESSION[PUROPOSID] > 2?$itmObj->OIDUnitCost:(($itmObj->UPDCQtyBreak2 > 1 AND $itmObj->Quantity >= $itmObj->UPDCQtyBreak2)?$itmObj->UPDCQty2Cost:(($itmObj->UPDCQtyBreak1 > 1 AND $itmObj->Quantity >= $itmObj->UPDCQtyBreak1)?$itmObj->UPDCQty1Cost:$itmObj->UPDCCost))));//c
   switch ($itmObj->OIDPPRate) {
    case 1:
        $itmObj->MPrice = (($itmObj->OIDStatusID > 7) AND ($itmObj->OIDStatusID < 10))?0:($_SESSION[OORDSTID] > 1?($itmObj->OIDStatusID == 7?abs($itmObj->Price)*-1:$itmObj->Price):round(($itmObj->Cost * $_SESSION['CustRate1']),2));//c
        break;
    case 2:
        $itmObj->MPrice = (($itmObj->OIDStatusID > 7) AND ($itmObj->OIDStatusID < 10))?0:($_SESSION[OORDSTID] > 1?($itmObj->OIDStatusID == 7?abs($itmObj->Price)*-1:$itmObj->Price):round(($itmObj->Cost * $_SESSION['CustRate2']),2));//c
        break;
    case 3:
        $itmObj->MPrice = (($itmObj->OIDStatusID > 7) AND ($itmObj->OIDStatusID < 10))?0:($_SESSION[OORDSTID] > 1?($itmObj->OIDStatusID == 7?abs($itmObj->Price)*-1:$itmObj->Price):round(($itmObj->Cost * $_SESSION['CustRate3']),2));//c
        break;
    case 4:
        $itmObj->MPrice = (($itmObj->OIDStatusID > 7) AND ($itmObj->OIDStatusID < 10))?0:($_SESSION[OORDSTID] > 1?($itmObj->OIDStatusID == 7?abs($itmObj->Price)*-1:$itmObj->Price):round(($itmObj->Cost * $_SESSION['CustRate4']),2));//c
        break;
    case 5:
        $itmObj->MPrice = (($itmObj->OIDStatusID > 7) AND ($itmObj->OIDStatusID < 10))?0:($_SESSION[OORDSTID] > 1?($itmObj->OIDStatusID == 7?abs($itmObj->Price)*-1:$itmObj->Price):round(($itmObj->Cost * $_SESSION['CustRate5']),2));//c
        break;
this code has many syntax errors such as this session referance:
$_SESSION[OORDSTID]
the session name should include single quotes:
$_SESSION['OORDSTID']
chris369732
Thank you, I am picking up where someone else had left off on this project, and I did not know about the extent of the changes that had been made. I will try to fix that function, and update you if the error persists.
