Search 'phrase' through Managed Relational Table
Thread begun 4/19/2013 8:32 am by paul386190 | Last modified 5/07/2013 8:31 am by paul386190 | 5798 views | 19 replies |
paul386190
Hi there, I wonder if anyone can assist. I'm creating a free text search (a single text-input named 'search-keywords') on a website for narrowing down a huge range of products, using the DataAssist Search feature.
The database has three tables:
1. Products: includes product_id, product_name, other product details
2. Keywords: incorporates keywords_id and keywords_name
3. KeywordProduct: incorporates KeywordProduct.KeywordProductID, KeywordProduct.KeywordProductProductID and KeywordProduct.KeywordProductKeywordID
Table 3 is a managed relational table so that a product can be assigned multiple keywords.
The products we have on the site include iPhone 3, iPhone 4, iPhone 5, iPad 2 and iPad 3 so we've opted to use keywords in the style of 'iPhone', 'iPad', '3', '4', '5', rather than complete model numbers as it will be easier when future models are brought out.
The struggle I'm having with the search is when more than one word is entered into the field. So if I search 'iPhone' I get all the products which have 'iPhone' assigned to them and if I search '5' I get all the products which have '5' assigned to them, but if I search 'iPhone 5' I get no results. What we need to happen in this instance is to get all products that have BOTH keywords assigned to them, not just either of them. I've tried a comination of 'include', '=', space for KEYWORD AND, and adding "" around the search term, but to no avail.
This is the code I currently have for the search...
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: rsproducts;
//Searchpage: ;
//Form: ;
$WADbSearch1_DefaultWhere = "";
if (isset($_POST["search_submit"]) || isset($_POST["search_submit_x"])) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
$KeyArr1 = array("keywords_name");
//comparison list additions
$WADbSearch1->keywordComparison($KeyArr1,"\"".((isset($_POST["search-keywords"]))?$_POST["search-keywords"]:"") ."\"","AND","Includes","%20","OR","%22","%22",0);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_masthead"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_masthead"]) && $_SESSION["WADbSearch1_masthead"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_masthead"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
And this is the query I'm using for gathering the products....
mysql_select_db($database_lazerbuilt, $lazerbuilt);
$query_rsproducts = "SELECT * FROM product, keywords, KeywordProduct WHERE product.product_id = KeywordProduct.KeywordProductProductID and KeywordProduct.KeywordProductKeywordID = keywords.keywords_id";
setQueryBuilderSource($query_rsproducts,$WADbSearch1,false);
$rsproducts = mysql_query($query_rsproducts, $lazerbuilt) or die(mysql_error());
$row_rsproducts = mysql_fetch_assoc($rsproducts);
$totalRows_rsproducts = mysql_num_rows($rsproducts);
I would be very grateful for any assistance.
Many thanks in advance
Paul
The Keyword search type should be set to includes.
For the key word and, enter a space. for the keyword or enter a comma
for the start encapsulator and end encapsulator enter double quotes.
paul386190
Hi Jason, many thanks for your response. Unfortunately that doesn't look to have resolved the issue. Please find below the new search code I'm using...
//Recordset: keywords;
//Searchpage: ;
//Form: ;
$WADbSearch1->keywordComparison($KeyArr1,"\"".((isset($_POST["search-keywords"]))?$_POST["search-keywords"]:"") ."\"","AND","Includes","%20",",","%22","%22",0);
if (1 == 1) {
else {
if (1 == 1) {
else {
else {
I've also placed "" around the value itself so that it reads..."<?php echo ((isset($_POST["search-keywords"]))?$_POST["search-keywords"]:""); ?>"... but that hasn't worked.
Is there anything else I've missed?
Many thanks in advance.
Paul
Note:
It's more helpful to have the full page in a zip file then to pate code segments in your message.
paul386190
Hi Jason, I've sent you a private message.
The problem is that you are searching on the keywords_name column, this column does not contain any records that have the string "iphone 5"
to troubleshoot this, i edited the mouse over text so it would show both the product name and keyword column:
title="<?php echo $row_rsproducts['product_name']; ?>||<?php echo $row_rsproducts['keywords_name']; ?>"
for all of the records where product name includes "iphone 5" the keyword only contains "iphone"
you're trying to search for a string that does not exist in the keywords_name column
paul386190
Hi Jason, many thanks for looking into it for me. But I was under the impression that I could do a search for all products that have more than one keyword associated to them, in this instance 'iphone' and '5'. Is this not the case?
Kind regards
Paul
By forcing the quotes in front of the string, you are forcing the search to look for the literal string "iphone 5"
if you want to search for iphone OR 5, then leave the quotes off the front of the string, and set the OR separator to a space
paul386190
Hi Jason, I seem to be back to square one again then mate. I don't want to return any results that have either 'iphone' or '5' assigned to them, I want to return all results that have both 'iphone' and '5' as separately assigned keywords. I've removed the forced quotes and used a space for AND and set the comparison as INCLUDES, but it still gives me no results. It would be the same as if they wanted to search 'black phone', I'd want to show all results that have both 'black' and 'phone' assigned to them. Really sorry if this is getting frustrating for you, it's pulling my hear out trying to establish the best way to get all the products set up for searching. Having read through loads of other posts, it seemed to be best to separate out all the search terms into a separate table and then use a managed relational table to join them to the products rather than having a 'keywords' field within the 'products' table and for each product filling it with all the relevant keywords.
Yours hopefully.
Paul
i dont follow. I'll need to do a screen sharing session
