custom shipping service
Thread begun 4/18/2013 12:39 pm by giancarlo.barba327402 | Last modified 4/22/2013 7:04 am by Jason Byrnes | 2076 views | 3 replies |
Hi
in the checkout wizard show only few shipping provider. My customer use a shipping service not listed there how i can create the rigt rules to calculate the right shipment cost? the shpipment cost are flat where i need insert the value? have a tutorial for this case? i am beginner wih ecart.
thank you
In the eCart object, on the shipping tab, you can create shipping rules.
the exact rule will depend on your needs for shipping. If you need further assistance, give more details on how you would like shipping to be calculated.
well i want set a flat cost for all shipment (e.g. 8 €).
this a s base
but if customer buy for more 50 € shipment are free
more
if customer live in some specific place shipment will cost flat another import (e.g. 15 €)
i am confused why in checkout wizard if my shipment service is not present i need check "i dont provide shipment"
thank you
You will not be able to set these rules in the wizard, you need to edit the eCart object to add these shipping rules.
in the checkout wizard, select to include shipping, but leave the provider at NONE since you will be calculating your own shipping rather than using a lookup service.
open the eCart object panel (Insert -> WebAssist -> eCart -> eCart Object) Select your eCart abject and click the edit button.
on the shipping tab, you can defeine the shipping rules.
for the base rate rule, use the trigger:
Subtotal for the entire Cart Contents - is "<" a value of "50"
for the calculation use a flat rate of 8
the shipping country is stored in a session value named:
eCartCheckoutForm_shipping_country
to charge different shipping rates to different countries, you can add conditions to the shipping rules using the based on session variable value trigger.
