"The user specified as a definer ('root'@'localhost') does not exist"
Thread begun 4/18/2013 7:37 am by john70964 | Last modified 4/20/2013 2:57 am by john70964 | 16060 views | 8 replies |
john70964
I have created a results details page in Dataassist but when I try to run the page I get the error
The connection is simliar to
# FileName="WADYN_CONN.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_ConnNo1 = "localhost";
$database_ConnNo1 = "xxx2013";
$username_ConnNo1 = "root";
$password_ConnNo1 = "password";
@session_start();
$ConnNo1 = mysql_pconnect($hostname_ConnNo1, $username_ConnNo1, $password_ConnNo1) or trigger_error(mysql_error(),E_USER_ERROR);
I have another site which works perfectly well where the connection is similar to:
# FileName="Connection_php_mysql.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_conn1 = "localhost";
$database_conn1 = "yyyy";
$username_conn1 = "root";
$password_conn1 = "password";
$conn1 = mysql_pconnect($hostname_conn1, $username_conn1, $password_conn1) or trigger_error(mysql_error(),E_USER_ERROR);
Can anyone see why the connection should no be working please.
Many thanks
John
judging by the error, your page is trying to access a stored procedure, when creating the stored procedure and the root user does not have privleges to run it.You will need to grant the root user privileges to access the stored procedure.
john70964
Thank Jason
I think the users are the same for both of these connections.
The error is saying otherwise.
the error is saying that the root user does not have access to the database being used by this connection.
john70964
Thanks Jason
I am attaching a picture of the set up perhaps you can see what I need to do to correct this.
Thank you
John
your screen shot shows the root@127.0.0.7 user, your connection uses localhost for the host name.
try changing the connection to use the 127.0.0.7 address for the connection.
john70964
Thanks Jason
I think you misread the 127.0.0.7 should be 127.0.0.1
When I changed hostname_ConnNo1 to 127.0.0.1 in the connection file I still get
The user specified as a definer ('root'@'localhost') does not exist.
when are you getting the error:
Testing the connection? or in the web browser when testing a page?
if when testing a page, what is the URL in the address bar?
if when testing the connection, what is the URL PRefix in the site settings for the testing server?
is your screen shot of navicat showing your local mysql database? or a remote mysql database?
john70964
I created a new user and the connection was made OK
Thanks for your help Jason
