upload file causes page not to load
Thread begun 4/18/2013 2:43 am by WhiteJC | Last modified 4/18/2013 12:12 pm by WhiteJC | 3680 views | 10 replies |
WhiteJC
I using DW4 and Universal Email 4.0.1 when I add a file upload my page won't load, all I get is a blank page, removing the file upload gives me my page back!? what am I doing wrong?
I've attached 2 screen grabs showing with and without file upload, you'll notice that no code appears to have been loaded with the file-upload version?
a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting
(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
WhiteJC
Hi Jason
here's the error message
Warning: require_once(webassist/file_manipulation/helperphp.php): failed to open stream: No such file or directory in /home/virtual-web/www.beaverswood.de/public/manPRODUCTa_Update.php on line 7 Fatal error: require_once(): Failed opening required 'webassist/file_manipulation/helperphp.php' (include_path='.:/usr/share/pear:/usr/share/php') in /home/virtual-web/www.beaverswood.de/public/manPRODUCTa_Update.php on line 7
that error means the that the file:
has not been uploaded to the server.
make sure to upload the entire webassist/ folder to the server.
WhiteJC
Hi Jason
there is a 44kb file named HelperPHP.php in the webassist\file_manipulation directory on the "live" site
by-the-by it works on my test system?
I'll need to see the site to troubleshoot further. see the private message section.
WhiteJC
the code was looking for:
but the file was named:
HelperPHP.php
i renamed the file to be the same case as what the code was looking for.
What version of Data Bridge do you? Make sure you have the latest version 1.1.3 installed.
WhiteJC
HelperPHP.php
see private message
