Script does not define the findServerBehaviors function with eCart 452.
Thread begun 4/17/2013 11:07 am by bobrossi315677 | Last modified 4/29/2013 5:32 am by bobrossi315677 | 3195 views | 4 replies |
bobrossi315677
When opening a page within Dreamweaver CS4 I get the following message "WAeCart08RedIFEMP script does not define the findServerBehaviors function" then "WAeCart UPS Script does not define the findServerBehaviors function." I think these appeared following the installation of Design Extender (after removing CSS Menu Writer 2 and Site Assist Professional) Looking at other posts seems that follwing the instructions at http://assets.webassist.com/technotes/common_installation_issues.pdf but in the Condiguration directory of the en_US directory, the WinFileCache.dat file does not exist.....I've uninstalled and reinstalled extentions, always selection replace all in the process, but I still have these error messages.
What extensions, including the version numbers are installed?
eCart should not be installed after design extender, so make sure to install eCart first then design extender.
bobrossi315677
Hi Jason, thanks for responding. I am using eCart 4.5.2 and Design Extender 1.1.1. I uninstalled both and reinstalled eCart first and then design extender. when opening a page in dreamweater with the cart function I get the same two errors. I seem to be able to edit menus and edit the cart buttons but have not actually tried this yet.
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
http://www.webassist.com/community/tutorials/view_tutorial.php?tid=95
bobrossi315677
Worked
Thanks Jason, that did the trick, i was confused about where to find the file. Thanks again.
