re-ordering data
Thread begun 4/16/2013 11:43 am by Jamie | Last modified 4/16/2013 1:11 pm by Jamie | 1454 views | 3 replies |
Jamie
re-ordering data
Hey Jason
Sometime ago, Ray worked with me on a premier ticket to help me be able to reorder data in _results page which I have reproduced on many occasions (an example of this is attached called diary_results.zip) and this works absolutely fine.
On an installation I have gone out of the mould (basically removed the _results from a table and put them in divs and I cant get the re-ordering aspect to work at all (see attached gallery_results.zip). the results page is showing '1' in all the fields and clicking 'update order' changes nothing in the database. Clearly I have done soemthing wrong with the syntax etc but just cannot see what it is....
Cheers
Jamie
move the code that sets the $curOrder variable to 0 at lines 435 - 437:
      $curOrder
0;
to line 417 so it is before the recordset loop:
      $curOrder
0;
              <?php do { ?>
by having it inside the recordset loop, it is reseting to 0 on each record.
Jamie
Thanks very much Jason
