Clearing specific session values
Thread begun 4/16/2013 4:09 am by mrs | Last modified 4/16/2013 8:48 am by Jason Byrnes | 1885 views | 4 replies |
mrs
I have selected to clear a couple of specific sessions in order to retain others, but the resultant code looks as though it's clearing all sessions...
@session_start();
if ("" == ""){
// WA_ClearSession
$clearAll = FALSE;
$clearThese = explode(",","WADA_Insert_tbl_products,WADbSearch1_products_results,captcha_Security_Code_1,WADA_Insert_tbl_KTCmainimg,
SecurityAssist_UserID,emailVerified,rpw,WADA_Insert_tbl_forumCTGRY,threadID,forumID,forumTITLE,forumNAME,
WADbSearch1_tbl_forumPOSTS_results,WADbSearch1_forum_results,userupdate_User_Update_group_Avatar,USES_access,USES_threadID,
USES_forumID,USES_forumTITLE,USES_forumNAME,USES_srREGION,USES_srVALUE,USES_rsSUBS,USES_rsPRICE,
registration_Registration_group_Avatar,events_insert_fld_eventIMG,WADA_Insert_tbl_events,WADbSearch1_users_results,WADA_Insert_tbl_year,
WADA_Insert_tbl_eventreport,WADA_Insert_tbl_forumNAME,WADA_Insert_tbl_forumPOSTS,WADA_Insert_tbl_users,
WADbSearch1_tbl_users_results,WADbSearch2_tbl_users_results");
if($clearAll){
foreach ($_SESSION as $key => $value){
unset($_SESSION[$key]);
else{
foreach($clearThese as $value){
unset($_SESSION[$value]);
It's only the last two in the list that I want to kill off (WADbSearch1_tbl_users_results and WADbSearch2_tbl_users_results), so should I remove all sessions listed other than these? I did select only the last two from the list within the wizard, but seem to have ended up with all sessions listed. So, I am not sure if this code is saying to keep all sessions, or kill them all.
The Clear these list should only contain the sessions that you want to clear. change:
$clearThese = explode(",","WADbSearch1_tbl_users_results,WADbSearch2_tbl_users_results");
In the Clear Session Values behaviors, any sessions that are in the list will be added. you need to select the ones you dont want to clear and click the trash can icon to remove them from the list.
mrs
That's as I thought. I have had this before, and cleared out those that I didn't want, but because ALL of my sessions keep appearing in the list, I had assumed I had done something wrong previously when selecting to clear specific sessions in the wizard.
So, currently when I run the wizard, is it meant to give me all sessions so I clear them out manually, or is it meant to only give me the code for the two selected sessions? Currently, each time I run the wizard, I am being presented with all sessions listed in the resultant code.
When you add a new clear session value server behavior, you will need to remove any sessions from the list that you do not want to clear.
if you edit an existing instance of the Clear session values behavior, it will show only the ones you selected initially.
