WA definition missing, Have just installed the upgrade and can't use anything. Wrote on this forum this morning your time but no answer. Please reply
Thread begun 4/15/2013 4:44 pm by rolf358571 | Last modified 4/22/2013 8:11 am by Jason Byrnes | 3967 views | 6 replies |
rolf358571
Universal email reports that wa is missing and if I start a new page, the same error comes up but now for random password generator. I have attached a screenshot.
This is an order or installation order. You cannot install eCart last or it will overwrite some newer shared files with older versions. The solution is to uninstall and re-install Data Bridge.
rolf358571
Excellent, I will uninstall and try again. The install documentation should then really list the order it should be installed in. In the pas with all extensions it asks if you want to replace an older / newer copy.
rolf358571
Data assist pages does not start
The solution you gave on the last problem worked, Thank you.
I know have another problem. When I try to use DataAssist and then go to Data Assist Pages in the menu, I get the followin errors as per attached. So I cannot open it. Would appreciate some help on this.
Best regards
Rolf
reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
http://www.webassist.com/community/tutorials/view_tutorial.php?tid=95
rolf358571
Thank you very much, it worked after I re-installed.
Another question that might not concern you.
I have a connection to MySQL that I used in Dreamweaver CS3 and has always worked fine, When I use the same connection in Dreamweaver CS6 I get an error, the connection fails, and have found that it is on fields that is set as Bit fields. As soon as I remove them, the connection works.
What should I use instead of Bit.
use the int data type.
