Using eCart for Room Service
Thread begun 4/11/2013 4:20 am by Heckie | Last modified 4/11/2013 9:01 am by Heckie | 2145 views | 5 replies |
Heckie
I would like to set up a system for guests to be able to add room service items to a database using eCart for calculating prices (variable quantities), and pay for it all once they checkout, which may be a week or 14 days later.
The first step is easy - create a normal eCart, then instead of checkout I insert the items into the database on cart.php submission. Each item is stored with a unique GuestID which is created when they log in (session).
What I need to be able to do is to get this information into a secondary (non-editable) eCart basket/cart page to allow them to pay when they checkout.
I can get the relevant items onto a page using a recordset and the GuestID parameter, but I am not sure how I can then generate the checkout for the total amount. I was thinking that I could create a second eCart Object, but I am not sure how to populate from items stored in database, rather than the live eCart session.
Maybe there is a way to just display the items using a standard recordset, then use a PayPal express checkout button with the total amount?
Any help/suggestions would be appreciated.
Thanks.
Use the eCart get contents from recordset behavior to populate the cart from a recordset
On the server behaviors tab, click the plus button and select eCart -> Add to Cart -> Get Contents from Recordset.
Heckie
Ah… thats pretty easy! Thanks for the reply.
Am I right to use 2 eCart objects or will one suffice?
i would use 2, one for the client that uses no gateway and stores to the database.
the other that is used by the hotel staff, populates from a recordset that looks up all the client charges, and processes through the gateway.
Heckie
Thank you - it works as required using 2 eCart objects.
