Data Assist crash everytime tried insert pages using it
Thread begun 4/10/2013 6:54 am by andrea.falco358266 | Last modified 4/15/2013 10:25 am by Jason Byrnes | 1405 views | 5 replies |
andrea.falco358266
I've the very last version of DataBridge installed on Dreamweaver CS6 (WIN). More or less everytime I tryed to create new pages through WebAssit/Database/DataAssist Pages this make dreamweaver collapase.
Can You help me?
are you using one of the preset applications? or using the New Form blank?
Are you using your own table? or have ing the preset create the table for you?
if using your own table, what is the table structure?
At what point does it crash? while setting up the pages? or while it is trying to create the pages?
If it is crashing while it is trying to create the pages, try closing the Files panel and the server behaviors panel if they are open before you start the wizard.
if it is crashing while setting up the application, try disabling the preview in the webassist preferences.
andrea.falco358266
Data AssistCrash
I'm using the 'New Form blank' option, with a very simple table (attached).
Reading on the forum I've already tried to make it works closing the file panel, the database panel and i've disabled the prewiev.
It crashs setting up the pages, not always at the same moment.
Andrea
andrea.falco358266
Data Assist Continue crashes
I'm still waiting for an answer. I am trying to use your extension but it's really impossible to use it. Every time I try to create the pages ' pages DataAssist wizard ' make the system crash.
I use Dreamweaver CS6 on windows 8, but I've tried to use it on windows 7 with the same result. I've asked to a my colleague who works on an Mac and he said to me that He has ended to work with your extensions because he has always the same problem.
I was able to reproduce this using your table definition on CS6 / Mac OS.
It seams to be caused by the Visibility column using the tinyint data type. I changed the data type to Int and was able to create the pages.
I have logged a bug that the tinyint data type causes Data Bridge to crash.
