Javascript Errors on insert..
Thread begun 4/10/2013 4:08 am by Andrew Dodd - ADDIGITAL | Last modified 4/10/2013 8:57 am by Jason Byrnes | 1682 views | 4 replies |
I'm trying to add Captcha to a form but when I use the menu, I get a Javascript Error as shown in the graphic attached.
I've deleted the cache file, uninstalled and reinstalled the extension with no improvement. The same behaviour is observed if I try to add a date picker (which I did for comparison.)
Am using the CC version of Dreamweaver CS6.
Any thoughts?
Andrew
In the Creative Cloud updates Adobe have Unexpectedly deleted the Objects/Forms folder from the configuration folder.
Here is a copy of that folder to place in the users configuration folder. see this page for details on locating the users configuration folder:
http://www.webassist.com/support/documentation/how-tos/Forms.zip
Replaced Forms..
I've replaced the Forms folder, deleted the cache and restarted Dreamweaver, to no avail. Any ideas?
make sure the forms folder is in the configuration/objects folder.
the folder i sent to you definitely contains the formInsert.js file, so as long as you place it in the correct location, it will fix the error.
