Dynamic drop down list using validation show if?
Thread begun 4/09/2013 10:32 pm by rikaG_510 | Last modified 4/13/2013 12:21 am by rikaG_510 | 3234 views | 9 replies |
rikaG_510
Conditional drop down list using validation show if?
Hi Jason,
I need to make a conditional drop down list, but not sure how to make this happen.
I made these tables in my database.
[ CountryCategory ]
id country
1 England
2 Wales
3 Scotland
4 Ireland
[CountryList]
id CountryCategory shops
1 1 shope#1
2 1 shope#2
3 2 shope#3
4 2 shope#4
And form area with 5 drop down menu for;
[CountryCategory]
[shops in England]
[shops in Wales]
[shops in Scotland]
[shops in Ireland]
It should work like this;
When a country name is chosen from a list populated with CountryCategory;
another dorp-down list appears depending on which country is chosen;
e.g)
If 1 (England) is selected from [CountryCategory], a drop-down list of [shops in England] will appear, and so on.
What's the best way to do this?
I read "Getting Start with Validation Tool" hoping to help me to understand, but the logic of validation is confusing me… you purposely make errors so you get to see/use "show if"?? Also, I'm confused with "Validation show if" and "show region utility".
Could you briefly tell me the steps to make this happen so I'll know where to start?
Thank you for your help,
Rika
What you are trying to do has nothing to do with validation.
for this you would use the Dynamic Drop Downs tool.
Create a recordset to return the Countries
Create a parent list on the page, and use the countries recordset to populate it. use the id column as the value and the country column as the label
Create another recordset for the CountryList table.
On the server behaviors panel, Click the plus button and select webassist -> Dynamic Drop Downs -> Create Dynamic Array.
Select to use the CountryList recordset. use the CountryCategory column as the Parent ID, the id column as the child ID and the shops column as the child lable.
Add the child select list to the page.
in design view, select the parent list, then open the behaviors panel, click the plus button and select webassist -> Dynamic Drop Downs -> Populate list from array.
use the CountryList dynamic array, select the main list as the parent list and the second list as the child list, make sure the behavior is applied to the onchange even.
rikaG_510
Oh...okay. No wonder whatever I was reading didn't connect to what I wanted to do!
Thank you Jason, for detailed guidance. I will give it a try.
Rika
rikaG_510
Jason,
I followed through your guidance.
It's not working, so I must be doing something wrong...
At the moment the child list appears as blank before/after the parent list is chosen.
(It shows contents alright without DD applied).
I attached my code for this. Could you take a look?
Thank you so much!
Rika
please post a link where i can see the problem to investigate.
rikaG_510
This morning I gave it a try from scratch, and this time it's working!
I made a comparison to before and after file, and found out that I made a strange line break in the middle of php code, and php code for "if ($row_list)" was placed to left floating area where menu lists were on the right floating area. Fixing these made the before file work as well.
Anyhow, thank you for your help!
rikaG_510
Jason,
Drop down lists are working great now. I'm facing another issue.
How do I pass the value of child list to confim page?
Also at the moment parent list (country) is passing id numbers, is there a way to pass the country name?
I am using ::::: value="<?php echo $_SESSION['name01']; ?>" :::::for text field to pass values and to be able to go back and force between a form page and confirm page, and eventually store the data to database.
:::::: Parent list (country) ::::::::
<select name="country" onchange="WA_FilterAndPopulateSubList(list_WAJA,MM_findObj('country'),MM_findObj('list'),0,0,false,': ')">
<option value="">Choose a country</option>
do {
<option value="<?php echo $row_country['id']?>"><?php echo $row_country['RewardCountryCategory']?>
</option>
} while ($row_country = mysql_fetch_assoc($country));
$rows = mysql_num_rows($country);
if($rows > 0) {
mysql_data_seek($country, 0);
$row_country = mysql_fetch_assoc($country);
</select>
:::::: Chile list (shops) ::::::::
<select name="list">
<option value=" "></option>
do {
<option value="<?php echo $row_list['id']?>"><?php echo $row_list['RewardCountryName']?>
</option>
} while ($row_list = mysql_fetch_assoc($list));
$rows = mysql_num_rows($list);
if($rows > 0) {
mysql_data_seek($list, 0);
$row_list = mysql_fetch_assoc($list);
</select>
the value from the child list passes the same way as the parent value.
the parent has to pass the ID in order for the child list to work.
on the page that the form posts to, add a recordset to look up the ID that is passed and show the country name.
rikaG_510
Hi Jason,
Thanks, it's all working now.
Your words sometimes sound like cleaver teachings of Yoda… I kind of struggle first trying to figure out what it really means, then the moment sparks, everything makes sense after that!
