Odd behaviour of Universal Email
Thread begun 4/09/2013 5:50 pm by mrs | Last modified 4/10/2013 8:32 am by Jason Byrnes | 2578 views | 6 replies |
mrs
I am struggling to get Universal Email to work for me in some ways. It's for a job website where people apply directly to an employer rather than through the agency. I am trying to notify the employer they have a new application for job XYZ and it's being emailed to their specified email address entered in the DB.
The from address is that from the submitted form. The 'To' address coming from a recordset, and I have also been adding and removing a second hard coded To address to test for sure. The thing is, the email only triggers when the hard coded address is there. If I remove the hard coded address, nothing seems to happen, or I think it's gong to another email address from another record even though the correct record has been loaded into the form page.
Also, the subject isn't being filled in by the DB. It's blank all the time. Just to clarify, I am receiving an email to the DB driven address only when a hard-coded email exists, therefore I assume it is pulling some data through the recordset to the email behaviour, but not all of the info
The recordset I am working with is called rs_vacancy and I've added 'global $row_rs_vacancy;' to the Blank_3.php created by UE, but no joy. I am also dumping the results of the emailing to the thank you page and it's showing that it's working as far as sending is concerned, but I can't see the correct email address that should be pulled from the DB.
I've attached the files in question to see if you can see anything wrong.
mrs
Just to let you know, I have temporarily removed the <?php @session_start(); var_dump($_SESSION); ?> in the thank you page just in case somebody tries to use the site! For the moment, the agency will have to forward emails from the hard coded address.
mrs
I have been through the PowerStore I have to see if there might be any clues I might find in there as to why my emails aren't pulling the correct data through, but I can only see similar code to what I have already implemented. So, I am wondering if my MySQL select query is wrong in some way even though it is displaying the correct data on the form page. I don't know really, I am just clutching at straws now!
The main concept that is preventing your page from working is variable persistence.
when the page loads, you are passing it a querystring variable:
direct_enquiry.php?fld_id=23
the action of the form does not pass that querystring variable though, so look at it this waY
Page Loads (fld_id=23) shows the correct recordset info.
Submit Form, action is direct_enquiry.php this reloads the page, but the fld_id querystring is not present, so the recordset is empty.
the form has been submitted, so it triggers the email behavior, but the recordset is empty so it's not working.
use the following code for the form action to force it to retain the querystring variable:
 action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != ""?"?".htmlentities($_SERVER["QUERY_STRING"], ENT_QUOTES):""); ?>"
mrs
Aha! OK, I'll give that a go.
For future reference, is this something that Universal Email is NOT able to handle, or have I just missed it in the wizard somewhere?
As always, thanks.
It has nothing to do with Universal Email.
It has to do with the form.
The form has no way of knowing that you are going to need the URL Variables on submit. and unless you need them, you should not pass them.
If you do need them, you will need to modify the form action to include them.
