How to do an automatic cart submit and redirect to checkout page
Thread begun 4/09/2013 10:14 am by rod431909 | Last modified 4/09/2013 1:10 pm by Jason Byrnes | 3473 views | 8 replies |
rod431909
I have a kind of unusual situation where I have a product page where I build the product SKU using user selections from a couple dropdown menus. Unfortunately I can't get to the product's unique db id this way. So I am forced to take the client to a detail page that shows the selected product (that way I can call the recordset) and then have them select a confirm your order button to get it into the eCart.
I would much prefer some way to automatically pass the info from this detail page directly into the cart without the client having to click the submit button. Does anyone know a way to automatically trigger the add to cart function after the recordset loads and redirect straight to the Check Out page?
Use the add to cart server behavio on the detail page rather than the add to cart button.
to use the add to cart servder behavior, go to the server behaviors panle, click the plus button and select eCart -> Add to Cart -> Add to cart.
Use the recordset for the trigger and the bindings, and set the goto page.
rod431909
Thanks Jason. Surely it can't be that simple? I'll let you know.
But it is that simple ;)
rod431909
Worked. Too cool. Although the Continue Shopping button on the checkout page doesn't work, but I can live with that. Thanks again!
The continue shopping button only works in conjunction with the add to cart button, it wont work in conjunction with the add to cart behavior.
rod431909
Thanks again Jason.
you're welcome.
