While executing onMouseDown in WADA-PageInsert.htm
Thread begun 4/09/2013 5:04 am by Rune Brynestad | Last modified 4/10/2013 11:53 am by Rune Brynestad | 2965 views | 7 replies |
Rune Brynestad
I am having a problem with DataBridge 1.1.3 I can not make a insert page because I keep getting an error
While executing onMouseDown in WADA-PageInsert.htm (see attached image)
I have already cleared the WinFileCache a number of times, uninstalled the extension and reinstalled.
I have also tryed with a clean configuration folder, but it does not help.
I have installed the Extensions in the following order: eCart, DesignExtender, Free Tools, DataBridge
Any Ideas ?
Regards
Rune
What are the steps you are taking to produce this error?
using the Data Assist Create Pages wizard?
or trying to add an Insert record behavior?
please provide some more details so i can try to reproduce the problem to find the cause.
Rune Brynestad
I'm using DataAssist - Create Pages Wizzard
I can create the results page. The error message shows when I add the fields I want on the Insert page and press OK (see attachment)
In the manage fields settings section, how are those elements you have selected set to display?
In the WebAssist preferences, try disabling the preview, it may be that the error occurs on trying to generate the search page preview.
Rune Brynestad
I have disabled the preview, but the error is still there.
When I look into the field settings I see that the first two fields is set to display as datepicker (which is correct in this case). If I change them to text, I'm able to have my insert and update page created.
When I reopen my preset and set the two fields to display as datepicker again, I get a new error message when the wizzard generates my pages:
While executing timer in WA_SiteTools_progressV2.htm (see attachment). The wizzards hangs on the Insert Page and I can't get any further.
So I believe it has something to do with the datepicker fields.
Ok, I will log this as a bug to have it corrected in the next update, in the mean time if you set the first field of the search page to be a text field, does that allow you to use a date picker for fields under it?
Rune Brynestad
No, it does not work at all with date picker for any field. The work around for me seems to be to create the pages with text field instead of date pickers and then add the date pickers manually afterwards.
Another question:
I have two datepicker field, Start and End. How can I validate the End date to make sure that it's equal or greater than the Start date ?
(End date must not come before Start date)
Thanks in advice.
Regards
Rune
