unInitialize error
Thread begun 4/05/2013 11:03 am by eric284736 | Last modified 4/05/2013 12:47 pm by eric284736 | 2017 views | 4 replies |
eric284736
unInitialize error
Hi Jason,
I ran the dataassist wizard for insert, update, results with an upload function.
When I try to open the server behavior panels for Insert record, Update record, upload file
extensions I get the error:
unInitialize error: RangeError: invalid array length
I cleared the dat file, uninstalled the extensions then re-installed in this order - ecart, data bridge. I am still getting the error.
Any thoughts?
thx
Eric
send a copy of the pages please.
eric284736
Here you go
thx
Eric
the error is caused the column name "size" in your table.
size is a javascript function name, so is causing errors.
to prevent this sort of issue from happening, the naming convention i like to use is to prepend the table to the column name.
for example, the table name is "Paintings", use that at the beginning of the column names:
paintingCateID
paintingTitle
paintingMedia
paintingSize
paintingPrice
paintingSold
paintingPhoto
paintingFramed
paintingSpecial
paintingDisplay
this way you will never run into a MySQL Reserved word, or javascript / PHP Function name in your table column naming.
eric284736
Thanks jason!!
