Navigation behind Slider
Thread begun 4/04/2013 1:02 pm by Cologne | Last modified 5/08/2013 6:45 am by Jason Byrnes | 4818 views | 9 replies |
Cologne
Hello,
my navigation hides behind my slider.
Is it about the zIndex?
localhero.de/
Cheers
Denis
in the menu.css file, edit the first rule:
ul#cssmw1 {
cursor: default;
list-style-type: none;
margin: 0 0 0 0;
padding: 0 0 0 0;
and add position:fixed; to it:
ul#cssmw1 {
cursor: default;
margin: 0 0 0 0;
padding: 0 0 0 0;
position: fixed;
Cologne
Hi Jason,
thanks, works great.
Will this be fixed in the future?
Cheers,
Denis
It's is a problem specific to your layout.
99.9% of the time, adding position fixed is not necessary and can actually break other functionality.
Cologne
hm, my layout is made with sculptor.
Can you see what the problem in my design is?
I like it and I want to use it as much as possible :-)
Denis
the header uses overflow hidden:
#outerWrapper #header {
background-image: url("../localhero_standard_images/header_background.png");
background-position: left top;
background-repeat: repeat-x;
height: 40px;
overflow: hidden;
the dropdown menu is considered overflow, so it gets hidden.
Cologne
is this, because I have Logo and Navigation next to each other?
no, it is because of the overflow style on the header.
Cologne
Jason,
the navigation now stays fixed on the page if you scroll :-)
http://localhero.de/
Help :-)
Denis
instead of adding position fixed to the menu css, remove the overflow hidden from the #outerWrapper #header
