Cursor: POINTER
Thread begun 4/02/2013 2:27 pm by Cologne | Last modified 4/06/2013 9:26 am by Cologne | 4831 views | 8 replies |
Cologne
Cursor: POINTER
is the "Cursor: POINTER" missing?
Cheers,
Denis
Missing from where?
the pointer is default cursor, so it does not need to be explicitly defined in css.
Cologne
In iE8 it does Not work.
what doesn't work?
you need to provide more details.
Cologne
Hi Jason,
I dont know what it is, maybe something easy, but I cant find the error.
login.php
in the frontEnd the Button does not work like it should (hover, pointer), in iE8.
in the backEnd it does.
test@test.de / testtest
Maybe you can have a look.
Denis
when i view your page using IE 8, and hover over the login button, the pointer turns to the hand with the index finger pointing at the button.
is this not what you are expecting?
Cologne
The strange thing is, on some pages it turns to the pointer and the hove effect works and the action takes place over the whole button, and on some pages you only can click on the button label to get an action.
ok, well, please give a link to a page that demonstrates the problem, and give a detailed explanation of what I should be looking for.
Cologne
login.php
Login: test@test.de / testtest
Button not working in iE8. The hover effect does not work, the pointer is not there, and the link action is only if you click the label.
frontend:
register_1.php
login.php
resetPassword_1.php
backend:
welcome.php
In the backend, the buttons are working fine:
changePassword.php
changePrivateDetails.php
and the other pages.
thats, what is so strange. I checkt the CSS link in the template, but its all ok.
Denis
