Help with Show Region Behavior
Thread begun 4/01/2013 2:16 pm by danny405167 | Last modified 4/02/2013 8:53 am by danny405167 | 2738 views | 5 replies |
danny405167
I being trying to protect portion of a page with SecurityAssist ShowRegion behavior. I have created a rule named "Survey" where I have set the following:
Value: 1
Criteria=
Compare to: <?php echo ((isset($_POST["code"]))?$_POST["code"]:""); ?>
On my index.php page I have one input box that redirects to survey.php page. The form shows only when the code of 1 is entered.
Before I added Universal email to the survey.php page, show region server behavior was working fine. After the code of the Universal email was added, the following happens:
When I entered the value of 1 or any other value on the index.php page, I get redirected to my thankYou.php page. It bypasses the survey.php page.
I am using Windows 7 pro DW cs 6 and the latest WA extensions.
The link is at buildersfence.com/survey/
On the index page, ,the name of the form submit button is "button"
on the survey page, the submit button also named button.
in the universal email behavior, you have the trigger set to Button: button pressed.
this is causing the form on the index page to trigger the UE behavior.
to prevent this, change the submit button name on the index page.
danny405167
Can you please me help on how to decipher these error messages
I added the following code at the very top of survey.php
error_reporting(E_ALL);
The results were:
Notice: Undefined index: waue_survey_1_Status in /services/webpages/b/u/buildersfence.com/public/survey/survey.php on line 81
Notice: Undefined index: waue_survey_1_Index in /services/webpages/b/u/buildersfence.com/public/survey/survey.php on line 82
Notice: Undefined index: waue_survey_1_From in /services/webpages/b/u/buildersfence.com/public/survey/survey.php on line 83
Notice: Undefined index: waue_survey_1_To in /services/webpages/b/u/buildersfence.com/public/survey/survey.php on line 84
Notice: Undefined index: waue_survey_1_Subject in /services/webpages/b/u/buildersfence.com/public/survey/survey.php on line 85
Notice: Undefined index: waue_survey_1_Body in /services/webpages/b/u/buildersfence.com/public/survey/survey.php on line 86
Notice: Undefined index: waue_survey_1_Header in /services/webpages/b/u/buildersfence.com/public/survey/survey.php on line 87
Notice: Undefined index: waue_survey_1_Log in /services/webpages/b/u/buildersfence.com/public/survey/survey.php on line 88
Warning: Cannot modify header information - headers already sent by (output started at /services/webpages/b/u/buildersfence.com/public/survey/survey.php:81) in /services/webpages/b/u/buildersfence.com/public/survey/survey.php on line 91
On my local server I get the same errors
Notice: Undefined index: waue_survey_1_Status in E:\vhosts\dev-2\survey\survey.php on line 81
Notice: Undefined index: waue_survey_1_Index in E:\vhosts\dev-2\survey\survey.php on line 82
Notice: Undefined index: waue_survey_1_From in E:\vhosts\dev-2\survey\survey.php on line 83
Notice: Undefined index: waue_survey_1_To in E:\vhosts\dev-2\survey\survey.php on line 84
Notice: Undefined index: waue_survey_1_Subject in E:\vhosts\dev-2\survey\survey.php on line 85
Notice: Undefined index: waue_survey_1_Body in E:\vhosts\dev-2\survey\survey.php on line 86
Notice: Undefined index: waue_survey_1_Header in E:\vhosts\dev-2\survey\survey.php on line 87
Notice: Undefined index: waue_survey_1_Log in E:\vhosts\dev-2\survey\survey.php on line 88
Warning: Cannot modify header information - headers already sent by (output started at E:\vhosts\dev-2\survey\survey.php:81) in E:\vhosts\dev-2\survey\survey.php on line 91
danny405167
Problem solved.
delete the webassist/email/mail_php.php and webassist/email/mailformatting_php.php pages from your site, then open the server behaviors panel and double click the Universal Email server behavior, and click the OK button to have those 2 files regenerated. make sure to upload the new versions to the server
danny405167
Thank you very much. Now I can move on with my next project.
