Need to add 8 hours to a DATETIME
Thread begun 4/01/2013 9:28 am by mrs | Last modified 4/02/2013 8:07 am by Christopher West | 6942 views | 8 replies |
mrs
Hi, I am running data bridge to create pages where a user inserts content, but I want to limit their ability to update the record once posted. I want to limit their ability to update the record to within 8 hours of it originally being posted. After eight hours, I am going to wrap the update with a WA show region behaviour to hide it.
What I am struggling with is how to add the eight hours to the record, or how I make the show if behaviour hide the update button after eight hours.
Is there a way?
<?php if(WA_Auth_RulePasses("PaidMember")){ // Begin Show Region ?>
CODE HERE
<?php } // End Show Region ?>
I set up a rules for PaidMember which compared the session MemberValidTo:
<?php echo $_SESSION['MemberValidTo']; ?>
to this code: <?php echo date('Y-m-d H:i:s'); ?>
So what you could do is something simular and just ad 8 hours to the current time:
Also could something like this work: for adding 8 hours
strtotime('+8 hours', strtotime(<?php echo date('Y-m-d H:i:s'); ?>));
Chris
mrs
I have been trying to get this to work based on the data bridge insert behaviour, and I have this working to post the current date and time:
.$_POST['fld_vLOCKDATE'] = date('Y-m-d H:i:s').
But, as soon as I try to amend it to add in the 8 hours extra, I end up with 0000-00-00 00:00:00 for my date and time.
This is what I have so far which isn't working:
.$_POST['fld_vLOCKDATE'] = date('Y-m-d H:i:s') + ('INTERVAL 8 HOURS').
or
.$_POST['fld_vLOCKDATE'] = date('Y-m-d H:i:s, INTERVAL 8 HOURS').
or
.$_POST['fld_vLOCKDATE'] = date('Y-m-d H:i:s' + '+8 HOURS').
and so on... many iterations of it now that I can't remember them all!
The following is what was produced as code straight from the Dat Assist extension:
.((isset($_POST["fld_vLOCKDATE"]) && $_POST["fld_vLOCKDATE"]!="" )?date("Y-m-d H:i:s", strtotime($_POST["fld_vLOCKDATE"])):"") .
And I've added the code you suggested to the hidden field in my form, but still no joy. Any thoughts on what I can do further?
Thanks so far anyway.
Another way of adding 8 hours you could use:
$date = date('h:i:s A', time()+28800);
(28800 = seconds) Which = 8 hours
(60 x 60 x 8)
Your probably getting 0000-00-00 00:00:00 as your calculation is adding to the whole datetime so it would end up becoming an invalid calculation. I never done this before, So would need to write the code myself when I am probably at computer.
Chris
perhaps something like:
<?php echo date('Y-m-d H:i:s' , time()+28800); ?>
could be implimented
Chris
ok I just done experimenting as I never done this before. how about this code...
as a test copy thid directly:
$new_time = date(strtotime($_POST['fld_vLOCKDATE'])+60*60*8);
<BR>
<?php echo date('l jS M Y H:i:s' ,$new_time); ?>
I tested the above code using a datime stored in a members table in my own database..this is the code I used:
$new_time = date(strtotime($row_rsMembers['MemberValidTo'])+60*60*8);
<BR>
currently stored in the members table under MemberValidTo is 2013-04-02 00:00:00
the output of the above code I used gives me: Tuesday 2nd Apr 2013 08:00:00
(Which is +8 hours on the date stored in my database :)
So the above can be altered for your post variable.
Chris
Ok I think I have something that uses a stored datetime in a users table in the database (if thats what you would want to do since if they update content you would want to store the datetime of that content entry in the users table). (28800 is in seconds = 8 hours)
Ive used long variable names to make the below example more meaningful:
Plus I am echoing the 2 variables just for demonstration of both datetimes to compare.
Its the first time I done this sort of thing so its a little crude :)
$currentdatetime = date('l jS M Y H:i:s');
$storeddatetimeandeighthours = date('l jS M Y H:i:s',strtotime($row_rsMembers['MemberValidTo'])+28800);
<?php echo $currentdatetime; ?>
<BR>
<?php echo $storeddatetimeandeighthours; ?>
<p>&nbsp;</p>
if ("".$currentdatetime ."" < "".$storeddatetimeandeighthours ."") { // WebAssist Show If
<p>This text will only show if under the datetime stored in database is less than 8 hours of current datetime</p>
} // ("".$currentdatetime ."" < "".$storeddatetimeandeighthours ."")
I think I was adding too much work in my previous post so here is a more simple version :)
if ("".date('l jS M Y H:i:s') ."" < "".date('l jS M Y H:i:s',strtotime($row_rsMembers['MemberValidTo'])+28800) ."") { // WebAssist Show If
(above is to demonstrate only so you would need to replace with your $_POST variables :)
Chris
Some more funky datetime manipulation:
As this is my first time experimenting with this I would like to share... So from the database which has a registration date of the member stored, if I wanted to add 1 month to their registration date and use that with a SHOW IF statement:
(The reason why I am using the timestamp stored in the members database rather then doing the calculation on the page then storing that result in the members table is that I may want to know the actual registration date somewhere else on the website...therefore this approach could have more flexability. especially If I store the "1 month" or "8 Hours" in a table in the database that I could then use as dynamic data...lets say you want to change the 8 hours to something else in the future..in your admin area you could have a page that stores that as well so you wouldnt need to edit the page code manually :)
$storeddatetimeandeighthours = strtotime(date($row_rsMembers['MemberValidTo']). '+1 hour');
<BR>
<?php echo date('l jS M Y H:i:s',$storeddatetimeandeighthours); ?>
<p>&nbsp;</p>
