DataBridge radio groups in my register page
Thread begun 3/30/2013 6:42 am by Paul | Last modified 3/30/2013 7:22 pm by Jason Byrnes | 1391 views | 3 replies |
PaulBeta Tester
I've used DB to create user reg and login pages, etc.
There seems to be an issue with handling radio groups in the wizard created register page.
When a user completes and submits a new form, my server responds with Column 'hoType' cannot be null.
Below is the code snip which refers to the issue.
The behavior i want is for a value 1 or 2 to be saved to my MySQL table.
This coding is not posting the value for some reason. Any ideas please?
html:
<div class="lineGroup">
<label for="Registration_group_hoType__1" class="sublabel" > hoType:<span class="requiredIndicator">&nbsp;*</span></label>
<div class="errorGroup"> <span id="Registration_group_hoType__1_Spry"> <span> <span class="radioFieldGroup_Wide"> <span class="radioGroup_Wide">
<label class="radioSublabel_Wide" for="Registration_group_hoType__1" onClick="hideServerError('Registration_group_hoType__1_ServerError');"> Seller&nbsp;
<input type="radio" name="Registration_group_hoType" id="Registration_group_hoType__1" value="1" class="formRadioField_Standard" <?php if (!(strcmp((isset($_GET["invalid"])?ValidatedField("register","Registration_group_hoType"):""),"1"))) {echo "checked=\"checked\"";} ?> tabindex="6">
</label>
<label class="radioSublabel_Wide" for="Registration_group_hoType__2" onClick="hideServerError('Registration_group_hoType__1_ServerError');"> Buyer&nbsp;
<input type="radio" name="Registration_group_hoType" id="Registration_group_hoType__2" value="2" class="formRadioField_Standard" <?php if (!(strcmp((isset($_GET["invalid"])?ValidatedField("register","Registration_group_hoType"):""),"2"))) {echo "checked=\"checked\"";} ?> tabindex="7">
</label>
</span> </span>
if (ValidatedField('register','register')) {
if ((strpos((",".ValidatedField("register","register").","), "," . "7" . ",") !== false || "7" == "")) {
if (!(false)) {
<span class="serverInvalidState" id="Registration_group_hoType__1_ServerError">Please enter a value.</span>
<?php //WAFV_Conditional register.php register(7:)
<span class="radioRequiredMsg">Please enter a value.</span> </span> </span> </div>
</div>
send a copy of the page so i can see the code in context.
PaulBeta Tester
register page attached.
in the insert record behavior, most of the database columns are bond to a form element named undefined.
open the server behaviors panel, in the list of server behaviors, double click the Insert record behavior to edit it. Go to the Bindings tab.
With the exception of the Primary Key ID Column, Select each database column and click the lightning bolt icon to select the corresponding form element from the bindings list.
