framework.php syntax error, unexpected T_STRING
Thread begun 3/29/2013 11:12 am by q_carlos322496 | Last modified 3/29/2013 6:57 pm by Jason Byrnes | 5876 views | 7 replies |
q_carlos322496
I am getting the following error when trying to access the webpage that I created using the framework builder extension. Can you guide me in the right direction as to how I might be able to resolve this:
Parse error: syntax error, unexpected T_STRING, expecting T_OLD_FUNCTION or T_FUNCTION or T_VAR or '}' in /home/craigm/public_html/webassist/framework/framework.php on line 3
The live page is located at this URL index.php
I will attach a copy of the webpage itself for you to reference.
send a copy of the index.php and webassist/framework/framework.php files i na zip archive please.
q_carlos322496
index.php is attached
I've attached the index page as you requested.
i had also requested the webassist/framework/framework.php file...
q_carlos322496
framework.php attached
I've attached the framework.php file that you had previously requested and I had overlooked.
what php version is your host running?
Framework bulder requires PHP 5.2 or grater.
q_carlos322496
php version
Apache version 2.0.64
PHP version 5.3.8
