Repeat Selection
Thread begun 3/28/2013 10:49 am by john70964 | Last modified 3/28/2013 2:55 pm by john70964 | 2033 views | 6 replies |
john70964
Repeat Selection
Hello
I am using the WA Repeat Selection but cannot get it to display the pictures horizontally.
They display vertically.
Can anyone see why this should be.
I am attaching a zipped file.
John
The repeat selection behavior wont display in a grid.
to create grid display, you need to use the Repeating table behavior.
WebAssist -> Database -> repeating table.
john70964
I think the repeat selection is being used already
I attach a picture.
John
yes, it is, and that's the problem.
the repeat selection behavior wont create a grid layout.
to create a grid layout, you need to use the repeating table behavior.
john70964
Ok I think I have this now!
in the repeating table behavior, set the rows to 1, and set the columns to all records this will create a one row table that will show all the records in a horizontal line.
john70964
Thanks Jason
That last comment was really helpful.
I summarise the method I used as,
Insert a Recordset
Insert a repeating table behavior. WA>Database>Repeating Table
Set the rows to 1, and set the columns to all records
This creates a Repeat Region and a Repeat Selection Behaviour.
Open the Repeat Selection SB set repetitions to 4
Replace comment in table [Your Repeated Content] with dynamic image.
Ammend Image Path as necessary. <img src="../images/
To place fields associated with image ie name etc
Highlight image press rt arrow and press enter.
Insert field from Recordset
Regards
John
