repeat region
Thread begun 3/28/2013 10:35 am by JamieEff | Last modified 3/28/2013 11:48 am by Jason Byrnes | 4141 views | 9 replies |
JamieEff
repeat region
not sure if this is the right forum, but have been bashing my head against a brick wall trying to figure out how to got the below as a repeat region....
html:
<div style="width:550px;">
<div id="TabbedPanels1" class="TabbedPanels">
<ul class="TabbedPanelsTabGroup">
<li class="TabbedPanelsTab" tabindex="0"><?php echo $row_StaffDetails['StaffName']; ?></li>
</ul>
<div class="TabbedPanelsContentGroup">
<div class="TabbedPanelsContent">
<div style="width:570px;">
<div style="float:right; width:380px;"><?php echo $row_StaffDetails['StaffBio']; ?></div>
<div style="float:left;margin:0 10px 5px 0; padding:10px; border: 1px solid #23363C; background-color:#8D9252;">
if(TRUE){ // Begin Cached Resized Image: ImageCacheInstance_1364489458477
ob_start();
<img src="uploads/images/staff-pics/<?php echo $row_StaffDetails['StaffPic']; ?>" width="150" height="150" />
echo(getCachedResizedImageHTML(ob_get_clean(), "uploads/images/staff-pics/", "crop", "", false));
} // End Cached Resized Image: ImageCacheInstance_1364489458477
</div>
<div style="clear:left;">
<div>
<h2>My Qualifications:</h2>
</div>
<div style="font-size:12px;margin-left:-20px;width:190px;"><?php echo $row_StaffDetails['StaffQuals']; ?></div>
</div>
<div style="clear:both;"></div>
</div>
<div> </div>
</div>
</div>
</div>
</div>
Any help gratefully received!
Jamie
select that code, then go to the server behaviors panel, click the plus button and select Repeat Region...
JamieEff
I've tried that (amongst other things) and it sort of works but puts each entry on its own line rather than in the tabbed panel framework
all right, well that gives a more complete picture of the actual problem, those details would have been helpful to know at the outset.
the repeat region should onbly go around the tab and contant group code, not the entire tabbed pannel
          </ul>
ob_start();
echo(getCachedResizedImageHTML(ob_get_clean(), "uploads/images/staff-pics/""crop"""false));
                </div>
                  <div>
                  </div>
                </div>
              </div>
              <div> </div>
            </div>
          </div>
JamieEff
have tried that already as well :(
ok, there needs to be 2 repeat regions, one around the tab LI elements and another around the tab content div.
here is a simplistic dynamic tab panels example i created:
    <?php do { ?>
      <li class="TabbedPanelsTab" tabindex="0"><?php echo $row_recordsetName['columnName']; ?></li>
      <?php } while ($row_recordsetName mysql_fetch_assoc($recordsetName)); ?>
  </ul>
    mysql_data_seek
($recordsetName0);
$row_recordsetName mysql_fetch_assoc($recordsetName);
    <?php do { ?>
    <div class="TabbedPanelsContent"><?php echo $row_recordsetName['columnName']; ?></div>
</div>
</div>
<script type="text/javascript">
var TabbedPanels1 = new Spry.Widget.TabbedPanels("TabbedPanels1");
</script>
note that before the second repeat region, i reset the recordset using this code:
mysql_data_seek($recordsetName, 0);
$row_recordsetName = mysql_fetch_assoc($recordsetName);
JamieEff
thanks Jason
I didnt have
    mysql_data_seek
($recordsetName0);
so guess thats where I was going wrong with the 2nd repeat region...
yeah, if you don't reset the recordset to the beginning, the 2nd repeat wont work, the recordset will be stuck at the end, nothing to repeat from there.
JamieEff
good to know and remember for the future :D
There is a behavior for this in Data Bridge:
on the server behaviors panel:
Click the plus button and select WebAssist -> Dynamic WebCharts -> reset to First Record
