Flash components are not working
Thread begun 3/28/2013 5:37 am by michaelf0199272 | Last modified 3/29/2013 3:12 pm by michaelf0199272 | 4641 views | 4 replies |
michaelf0199272
The flash portion of this website www.freefallnet.com/ does not work. When it is load independently it seems to work just fine. globenav.swf
Q: Does anyone know why it does not work in www.freefallnet.com/
*** Let me say that site only loads using google chrome
Thank you in advance
There are numerous issues with the way this page is created.
there is the script to create the left nav flash object, then the page body and html tags are closed, then follows the script for the global nav flash object. another issue is that the global nav and side nav objects are both using the same name, they should have unique names.
</table></div>
<div class="left_nav">
// <![CDATA[
var so = new SWFObject("/flash/sidenav_new.swf", "globenav", "196", "550", "8", "#FFFFFF");
so.addParam("wmode", "transparent");
so.write("nav1");
</script>
</div>
</td>
</tr>
</table>
</td>
</tr>
</table>
<!-- WiredMinds eMetrics tracking with Enterprise Edition V5.4 START -->
<script type='text/javascript' src='https://count.carrierzone.com/app/count_server/count.js'></script>
<script type='text/javascript'><!--
wm_custnum='454d300f07513d92';
wm_page_name='index.php';
wm_group_name='/services/webpages/f/r/freefallnet.com/public';
wm_campaign_key='campaign_id';
wm_track_alt='';
wiredminds.count();
</script>
<!-- WiredMinds eMetrics tracking with Enterprise Edition V5.4 END -->
</body>
</html> </td>
<td valign="top"><img src="/images/main_pic.jpg" align="texttop"></td>
</tr>
<tr>
<td valign="top">
<table cellpadding="0" cellspacing="0" width="520px">
<tr>
<td valign="top">
<div id="globe_nav1" style="padding:10px 10px 0px 10px">
<img src="images/g.png" border="0" align="top" usemap="#Map" />
</div>
// <![CDATA[
var so = new SWFObject("/flash/globenav.swf", "globenav", "282", "285", "8", "#FFFFFF");
so.write("globe_nav1");
</script>
</td>
<td valign="top">
<div id="kudos"><img src="/images/kudos.jpg" align="top">
</div>
// <![CDATA[
var so = new SWFObject("/kudo.swf", "kudo", "223", "285", "8", "#FFFFFF");
so.write("kudos");
</script>
</td>
</tr>
</table>
</td>
</tr>
<tr>
<td colspan="2"></td>
</tr>
</table>
<map name="Map" id="Map">
<area shape="rect" coords="13,1,133,122" href="http://www.a2ztext.com" />
<area shape="rect" coords="154,3,276,124" href="voice_trafficking.php" />
<area shape="rect" coords="154,138,272,261" href="wireless_broadband.php" />
<area shape="rect" coords="13,140,133,262" href="http://www.voipbizsolutions.com" /></map>
wm_track_alt='';
wiredminds.count();
</script>
</body>
</html>
michaelf0199272
My flash component is not loading still
// <![CDATA[
var so = new SWFObject("<?php echo $path_flash;?>/globenav.swf", "globenav", "282", "285", "8", "#FFFFFF");
</script>
Q: is something wrong with the statements above?
Note:
globenav.swf is in a folder named "flash" so are the rest of the flash components
if you look in the browsers error console, there are errors for the flash objects:
ReferenceError: Can't find variable: SWFObject
the SWFObject should be defined in the js/swfobject.js file:
swfobject.js
that file is empty though
michaelf0199272
Thank you very much Jason.
