Evaluating if a item is in the shopping cart
Thread begun 8/12/2009 11:13 am by terry164844 | Last modified 8/12/2009 1:51 pm by Jason Byrnes | 1594 views | 1 replies |
terry164844
Is there a way to determine if a particular item is in the shopping cart by reading/evaluating the ecart variable?
For example, if there is a product in the shopping cart, I want to display a msg to the user.
Terry
eCart has a function named "InCart" that takes the items ID, for example you could test for an item with the ID of 1 in the cart using:
<?php if($eCart1->InCart("1") == true) echo("Your Message"); ?>
this example assumes that the name of your cart object is "eCart1", if you cart object is named differently, replace "eCart1" with the name of your cart object.
