Error: Exception thrown in native function
I'm getting this error during a site important that stops the import at that point. Can someone advise what may be the problem and a solution?
What Extensions, including the version numbers are installed?
Does this error happen after site import has imported some of the site pages?
If so I would something in the site is causing the problem.
In the directory you set site import to save the files to, there will be an ImportLog.txt file, send a copy of that file, it may help determine what is going wrong.
Design Extender and Data Bridge latest versions. Yes it runs into problems part way through the import and there are files downloaded. I can't successfully attach the log file because it exceeds the 19.5 kb limit is what I'm told.
compress it to a zip file and attach the zip.
Seems a little odd needing to zip a 37k file but see attached.
