Sorting the eCart Display
Thread begun 8/12/2009 11:10 am by terry164844 | Last modified 8/13/2009 11:08 am by Eric Mittman | 1686 views | 1 replies |
terry164844
Is there a way to sort the items in the shopping cart display when the user views the checkout page?
I've setup the id on each product to be numeric and wanted to display the shopping cart based on the ID in asc order.
Terry
There is not a built in function or method that will allow you to rearrange the items by id like this. It is possible to do this but it would require creating a custom function that will need to do a couple of things.
You will first need to loop through the contents of the cart and get the itemIDs, then you can store these in an array. You can then create a new items array based on the itemIDs array, and finally you would set the items array for the cart to be the values from your newly sorted items array.
This might be a little difficult depending on your knowledge of php and experience with this type of manipulation.
