GET and Server Validation
Thread began 3/26/2013 4:33 pm by Cologne | Last modified 3/27/2013 10:10 am by Jason Byrnes | 1185 views | 3 replies |
Cologne
Hello,
I got 2 server validations on my page. 1 before page loads to check the $_GET and the 1 to check the from.
But the $_GET check directly goes to the restricted page :-(
if ("" == "") {
$WAFV_Redirect = "restricted.php";
$_SESSION['WAVT_login_375_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateLE($_GET['login'] . "",false . "",false,6);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"login_375");
if (isset($_POST["buttonLogin"]) || isset($_POST["buttonLogin_x"])) {
$WAFV_Redirect = "login.php";
$_SESSION['WAVT_login_093_Errors'] = "";
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateRX(((isset($_POST["title"]))?$_POST["title"]:"") . "","/^$/i",false,1);
$WAFV_Errors .= WAValidateEM(((isset($_POST["username"]))?$_POST["username"]:"") . "",true,2);
$WAFV_Errors .= WAValidateAN(((isset($_POST["password"]))?$_POST["password"]:"") . "",true,true,true,false,"üöäßÜÖÄ_-$§&#*€@",true,3);
$WAFV_Errors .= WAValidateEL(((isset($_POST["password"]))?$_POST["password"]:"") . "",6,50,true,4);
$WAFV_Errors .= WAValidateRX(((isset($_POST["product"]))?$_POST["product"]:"") . "","/^$/i",false,5);
PostResult($WAFV_Redirect,$WAFV_Errors,"login_093");
if(isset($_POST["buttonLogin"]) || isset($_POST["buttonLogin_x"])){
$WA_Auth_Parameter = array(
"connection" => $Localhero,
"database" => $database_Localhero,
"tableName" => "members",
"columns" => explode($WA_Auth_Separator,"username".$WA_Auth_Separator."password".$WA_Auth_Separator."flag"),
"columnValues" => explode($WA_Auth_Separator,"".strtoupper(((isset($_POST["username"]))?$_POST["username"]:"")) ."".$WA_Auth_Separator."".WA_CryptEncryption(((isset($_POST["password"]))?$_POST["password"]:"")) ."".$WA_Auth_Separator."1"),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text".$WA_Auth_Separator."int"),
"sessionColumns" => explode($WA_Auth_Separator,"id".$WA_Auth_Separator."flag"),
"sessionNames" => explode($WA_Auth_Separator,"memberID".$WA_Auth_Separator."memberLevel"),
"successRedirect" => "members/diver.php",
"failRedirect" => "login.php?login=false",
"gotoPreviousURL" => FALSE,
"keepQueryString" => FALSE
WA_AuthenticateUser($WA_Auth_Parameter);
I check entry is like = false
But this seems not to work.
Any help/suggestions?
Denis
the like entry validation is intended to comp[are 2 variables, not a variable to a string.
change the code:
$WAFV_Errors .= WAValidateLE($_GET['login'] . "", "false",false,6);
so that false is treated as a string.
Cologne
hmm, I did, but now the page login.php directly moves to the restricted page.
yes, thats because the validation is checking to make sure that the login querystring is equal to false. you have to include the login=false querystring:
