No default text in HTML editor instance on Update Page
Thread begun 3/26/2013 10:32 am by Andrew Read | Last modified 3/26/2013 12:21 pm by Andrew Read | 1149 views | 2 replies |
Andrew Read
:: Win7 x64, DW CS5.5, WADB 1.1.3 ::
I have a HTML editor instance created by WADB on my update form and it contains no default data. There is data in the database, but I don't see it on the page. Any ideas?
<div class="lineGroup"> <label for="activ_pgContent" class="sublabel" > Page Body:<span class="requiredIndicator">&nbsp;*</span></label>
<div class="errorGroup">
<span><?php
// The initial value to be displayed in the editor.
$CKEditor_initialValue = "".((isset($_GET["invalid"])?ValidatedField("formUpd","table_pgContent",false):"".$row_WADArecordset["table_pgContent"]."")) ."";
$CKEditor = new CKEditor();
$CKEditor->basePath = "../../webassist/ckeditor/";
$CKEditor_config = array();
$CKEditor_config["wa_preset_name"] = "Full";
$CKEditor_config["wa_preset_file"] = "Full.xml";
$CKEditor_config["width"] = "514px";
$CKEditor_config["height"] = "350px";
$CKEditor_config["skin"] = "kama";
$CKEditor_config["dialog_startupFocusTab"] = false;
$CKEditor_config["fullPage"] = false;
$CKEditor_config["tabSpaces"] = 4;
$CKEditor_config["toolbar"] = array(
array( 'Cut','Copy','Paste','SpellCheck'),
array( 'Undo','Redo'),
array( 'Bold','Italic','Underline','Subscript','Superscript'),
array( 'NumberedList','BulletedList','-','Outdent','Indent'),
array( 'JustifyLeft','JustifyCenter','JustifyRight','JustifyBlock'),
array( 'Link','Unlink','Anchor'),
array( 'Table','Rule','SpecialChar'),
array( 'FontName','FontSize'),
array( 'TextColor','BGColor'));
$CKEditor_config["contentsLangDirection"] = "ltr";
$CKEditor_config["entities"] = false;
$CKEditor_config["pasteFromWordRemoveFontStyles"] = false;
$CKEditor_config["pasteFromWordRemoveStyles"] = false;
$CKEditor->editor("activ_pgContent", $CKEditor_initialValue, $CKEditor_config);
if (ValidatedField('formUpd','formUpd')) {
if ((strpos((",".ValidatedField("formUpd","formUpd").","), "," . "7" . ",") !== false || "7" == "")) {
if (!(false)) {
?><span class="serverInvalidState" id="Update_group_ServerError_8">Please enter a value.</span><?php //WAFV_Conditional formUpd.php formUpd(7:)
</span>
</div>
the code looks correct, I'll need to see it on the server.
Andrew Read
Just reporting back..
This was an encoding issue DB vs web page.
Solved by adding a charset to the database connections file.
# FileName="Connection_php_mysql.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_connection_name "localhost";
$database_connection_name"DatabaseNAME";
$username_connection_name"UserNAME";
$password_connection_name"Password";
$connection_namemysql_pconnect($hostname_wtse_adm$username_connection_name$password_connection_name) or trigger_error(mysql_error(),E_USER_ERROR);
Simply add this with your charset to the end:
mysql_set_charset('utf8',$connection_name);
So it will look like this:
# Type="MYSQL"
# HTTP="true"
$connection_name=  mysql_pconnect($hostname_wtse_adm$username_connection_name,  $password_connection_name) or trigger_error(mysql_error(),E_USER_ERROR);
Or you can use a DA Dynamic Connection which allows you to set the charset.
