Multiple list items
Thread begun 8/12/2009 10:44 am by dmtompki336862 | Last modified 8/12/2009 1:42 pm by Jason Byrnes | 1788 views | 1 replies |
dmtompki336862
Multiple list items
Can eCart Add items handle multiple list objects?
For example I have a form with mulitple size cakes, the user needs to select both cake flavor and cake icing before adding to cart. The Add to Cart interface seems to be having difficulty adding two lists.
yes, you can have more than one list for the add to cart button.
First you need to create new columns in the eCart object for flavor and size. make sure these are both set to be unique.
Then in the Add to cart button wizard, on the bindings panel set each of those columns to be upateable from select lists.
You will need to populate each of the select lists that are created with the values for the Size and Flavor.
