Date Format (ii)
Thread begun 3/26/2013 8:02 am by salaroche | Last modified 3/27/2013 7:51 am by Jason Byrnes | 2397 views | 3 replies |
salaroche
Date Format (ii)
Hi:
The following code transforms the US date format mm-dd-yyyy to the DB format with no problem:
<?php require_once('Connections/dennfree.php'); ?>
if($_SERVER["REQUEST_METHOD"] == "POST") {
$_POST['S_date'] = "".((isset($_POST["S_date"]))?date("Y-m-d", strtotime(str_replace("-", "/", $_POST["S_date"]))):"") ."";
However. when using that very same code for doing a date-range search, it just doesn't work. In contrast, when entering the date in the European format dd-mm-yyyy the date-range search works well.
Any suggestions on how to solve this?
Just in case, attached please find the date-range search page in question with the dd.mm.yyyy format coded.
Thank you for your attention.
you have put that code on the search page, it needs to go on the results page.
if you continuer to have a problem, send a copy of both pages and a link where i can see the problem.
salaroche
Jason:
Attched please find the search and the results pages in question. If you needed to visit the Website to check out the problem live, please open a ticket where I can post the logging info.
