SA Create Pages: Form Validation & Field Settings
Thread began 3/25/2013 3:46 pm by Paul | Last modified 3/27/2013 6:53 am by Jason Byrnes | 698 views | 3 replies |
PaulBeta Tester
I'm using current version of DB in CS5.5.
I'm attempting to setup a registration page, login, update and forgot password page using the wizard.
I've just realised that for each page, the form field attributes are all shared.
To explain further...
If for example I set the password field to 'hidden' in my registration page, and then change it to 'editable' in the update page, the same field in the registration page reverts to what ever it was last changed to. This is really frustrating because I need to tailor each form with different visible, hidden and editable form field attributes.
Unless ive missed something, it doesn't appear that this extension allows me to do this.
Any comments please?
Yes, the attributes are shared for all pages in the wizard.
to use a different element type on each page, you would need to edit the element type after the page has been created by the wizard.
PaulBeta Tester
Hmm as I figured.
Is this functionality worth submitting as a wishlist item?
You can certainly submit a feature request to the wish list forum if you like.
