Populating the Email Log Database
Thread begun 3/25/2013 11:47 am by robcorrick409194 | Last modified 4/09/2013 9:52 am by robcorrick409194 | 4390 views | 11 replies |
robcorrick409194
I have created a new database on Godaddy and new database connection in Dreamweaver, as set forth in the instructions. I select the "Create the Log Table for Me" in the Response Pulldown in the "Create Email Message: Email Log Bindings" dialogue box. After updloading, it seems to be loading to my testing server not to Godaddy, so I do not get my database populated with tables. This seems to be a default by Webassist, but not sure. Any guidance would be appreciated.
are you testing locally?
When testing locally it will connect to your local mysql server.
to connect to the GoDaddy data base, you need to edit the database connection file with the details for connecting to the godaddy mysql server, then upload the files to your host and test the files on your host.
robcorrick409194
Populating the Email Log: Permissions Error
Thanks Jason for your previous post. I should have known to change the connections file, which I have now done. Thank you again for this fix.
I now receive the following error message in the "Create Email Message: Email Log Bindings" Dialogue Box:
"The current database connection does not permit creating tables. In order for Universal Email to create the email_log table for you, you will need to modify the MYSQL security settings for the current user or update your database to use a different user."
I went into my server database and successfully created a test table myself using phpmyAdmin on Godaddy. In addition, previously, I had no problem with the Webassist software setting up the tables in the databases for DataBridge and PowerMessenger, which seem to use the same permissions.
I am using three database connection files (with separate host, username, passwords specified): one for the DataBridge users database, one for the PowerMessenger user database, and one for the Email Log database. To populate the Email Log database, I reference the Email Log connections file in the "Connection" pulldown of the Dialogue Box, which appears to successfully connects to my hosting server.
So what I am missing here? Thanks.
the error message is pretty strait forward, the user in the connection does not have the privileges needed to create a table.
you can create the table manually buy running the following SQL:
CREATE TABLE `email_log` (
`EmailID` int(11) NOT NULL AUTO_INCREMENT,
`EmailTo` varchar(250) DEFAULT NULL,
`EmailFrom` varchar(250) DEFAULT NULL,
`EmailSubject` varchar(250) DEFAULT NULL,
`EmailBody` text,
`EmailHeader` text,
`EmailError` text,
`EmailStatus` varchar(50) DEFAULT NULL,
`EmailDate` timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP,
PRIMARY KEY (`EmailID`)
) ENGINE=MyISAM AUTO_INCREMENT=8 DEFAULT CHARSET=latin1
robcorrick409194
Email Log
Thank you Jason for your previous post where you proved the code to manually populate the email log database table. This works very well. Is there any reporting functionality for the email log available through Webassist or must I create my own report page, recordsets, bindings, etc.?
Great product.
A reporting page is not created, it only stores the info in the log table.
You would need to create the reporting page manually.
robcorrick409194
Universal Email JS error
Jason, Thanks to your help in your previous posts. Email logging is now working great. All of my emails are being saved now and a have a reporting page by UserID.
Java Script Error: I pass the current UserID in the Universal Email form to the email log record. In some cases, however, I receive the following error message: "While executing applyServerBehavior in CreateEmailMessageWA.htm, a JavaScript error occurred." This occurs when I am trying to bind the UserID from the email form to the email log database (where I have created a new field of UserID). Any suggestions to solve this problem? Where is the file CreateEmailMessageWA.htm? Thanks again.
robcorrick409194
Eliminate Universal Email Body Formatting
Is there any way to delete the formatting in the body of the Universal Email log? Examples of formatting that I would like to delete are: "--WAMULTIBREAKWA Content-Type: text/plain Content-Transfer-Encoding: 8bit". I though that I saw this topic in this forum, but I cannot find it now. Thanks.
i think this is the thread you are referring to?
showthread.php?t=21754
The new versions uses a global variable instead of a session, so the code will be slightly different but the same concept.
robcorrick409194
Deteting Email Log Format Success
Thanks for the code Jason. The new code works perfectly even though a $GLOBAL variable was not used.
I do not have my answer to the JS problem with the CreateEmail server behavior, but I will open this in a new thread.
