preg_replace
Thread begun 3/25/2013 3:06 am by JamieEff | Last modified 3/25/2013 12:28 pm by JamieEff | 2432 views | 4 replies |
JamieEff
preg_replace
Hey guys
Am trying to use pre_replace to remove the <img> and <a> tags from some content so that I can use it as a meta description.
Individually they work fine:
html:
<meta name="description" content="<?php echo(str_replace(array("<p>","</p>"),"",substr(preg_replace("/<img[^>]+\>/i", " ",$row_BlogRS['BlogContent']),0,250))."..."); ?>">
or
html:
<meta name="description" content="<?php  echo(str_replace(array("<p>","</p>"),"",substr(preg_replace("/<a href=\"(.*)\">/i",  " ",$row_BlogRS['BlogContent']),0,250))."..."); ?>">
But if I try to combine them the meta description on the resulting page is blank:
html:
<meta name="description" content="<?php echo(str_replace(array("<p>","</p>"),"",substr(preg_replace("/<a href=\"(.*)\">/i", "/<img[^>]+\>/i", " ",$row_BlogRS['BlogContent']),0,250))."..."); ?>">
what am I doing wrong please?
Many thanks
Jamie
you need to use 2 separate preg_replace functions, one to remove images, and another to remove anchors.
due to the complexity of what you are trying to accomplish, it may be better to create a function to perform each string manipulation rather than trying to add them all inline.
JamieEff
Um.... how would I do that please Jason?
create the function in the document head to perform each string conversion, for example:
function convertString($string) {
$retStr $string;
$retStr str_replace(array("<p>","</p>"), ""$retStr);
$retStr preg_replace("/<a href=\"(.*)\">/i"" "$retStr);
$retStr preg_replace("/<img[^>]+\>/i"" "$retStr);
    return
$retStr;
the you can call the function in the echo statement tag:
<?php echo(convertString($row_BlogRS['BlogContent'])); ?>
JamieEff
That's great. Thanks for the tip :)
