Show Region Question
Thread begun 3/23/2013 6:08 pm by Kamen Nikolov | Last modified 3/29/2013 2:37 pm by Kamen Nikolov | 8650 views | 34 replies |
Kamen Nikolov
My page product page (products_results.php and products_details.php) are working fine. I just want to add an additional feature to the products. A drop down menu with Product Sizes. The problem is a have mix products like clothing and products which are clothing products. So for one I need the dropdown with Sizes and for the other one I don't have to show it.
What should I do and how should I handle this challenge in order to have this feature on the page and in order to transfer the info through the checkout? Can Show Region handle this?
Thank you very much.
CraigRBeta Tester
you would need to add the column to your cart object to store the size, it would just be empty for the products which don't have it.
you could do some conditional logic on your cart page to show this information only if it is present
on your product detail page, you could wrap the select list for the size options in a show region if recordset is not empty behavior.
Kamen Nikolov
I am adding this under Columns and I am leaving the ProductSize in the DB empty as 0 or nothing?
CraigRBeta Tester
in the database, in which table are you asking about ?
I don't know how your database is structured
If some of your products have different sizes, you should have a table to store the product size for each product, linked to the products table
Kamen Nikolov
I have a table with all my size called "productsize" and I have the drop-down menu pulling the info from it. In the main "products" table I have I have another table called "ProductSize" which is empty ed the moment.
mrs
I suggest that you watch this video by webassist:
watch?v=6JBfwp-4B1Y&list=PL1F359A82D04D2329&index=2
it is for a paypal cart, but it shows you a way to deal with options such as sizes, or it could be colours or what ever you need options to be. Wrap the options with the Data Assist show region behaviour from the server behaviours panel... show if options <> 0. If you have no options available, then it will hide everything related to those options.
An example of it in use is here:
store.php
Scroll down the list to see it used in different ways, but it is driven by the same DB column.
I have hidden the add to cart button because the prices have yet to be sorted out, so I don't want people trying to be smug and buy for nothing if you were wondering.
Kamen Nikolov
Thank you for this info. I appreciated.
I don't see Data Assist show region behaviour from the server behaviors panel. Any ideas?
CraigRBeta Tester
The server behaviors panel is part of dreamweaver.
Make sure you are looking at 'server behaviors' and not 'behaviors'
Press Ctrl+F9 to view the server behaviors panel if it is not already visible, then click the + button, show region is about the fourth item on the list
Kamen Nikolov
I was looking for Data Assist show region behavior - there isn't one. Am I picking When RecordSet is empty or Not Empty? I am not sure what to do with <> 0 because none of them offer this option. So it will hide everything and how and where to specify where to show it and when not to.
CraigRBeta Tester
The recordset for your select list should only contain records when the relevant product id has been selected.
You can then add a 'show if recordset is not empty' server behavior around your select
