Music Upload not Working
Thread begun 3/23/2013 6:11 am by salaroche | Last modified 4/29/2019 10:14 am by Ray Borduin | 4767 views | 9 replies |
salaroche
Hi:
When uploading photos with Upload Files Server Behavior everything works well, but when trying to upload music, neither the Server File Name nor the song is uploaded?
Any suggestion on how to solve this?
Thank you for your attention
salaroche
I've been looking around and it seems that DW doesn't support MP3 uploading. Hope that's not true.
salaroche
Actually, I found a posting by Jason that points here:
wa....asp?page=php2
But I still haven't figured out the Upload issue. Any suggestons?
salaroche
Anyone out there?
I just changed the ini file like this:
Maximum allowed size for uploaded files.
; upload-max-filesize
upload_max_filesize = 10M
...(default is 2M) but still nothing....
salaroche
Please disregrad this issue. I already solved it.
clintonstroud447083
Originally Said By: salaroche
  Hi:
condos for sale in aventura Florida
I am also experiencing same sought of problem while uploading photos. Can you guide me how you've solved the problem?
to troubleshoot the upload, add the following code at line 1:
error_reporting
(E_ALL);
if(isset(
$_FILES)) var_dump($_FILES);
then go to the bindings panel, and expand the WA Uploaded Files Global Status group and add the debug info binding to the page in the body section.
post back a copy of the page in a zip archive, and the results after attempting to upload a file.
anonymous
DW Might Not Support Mp3 Upload
  Hi:
Hi, a lot of users are facing the same issue. Maybe it is because DW does not support music upload. Hope they fix the issue soon
Music upload is fine. It may just be a file size limit that needs to be adjusted on the server.
anonymous
hi there,
all you need to do is add digital file "upload" fields to your Dreamweaver forms from a wizard and you can have complete control over what can be uploaded, where the file is stored and more.
Hope this works for you.
