Incorrect path in dB when images are uploaded
Thread begun 3/22/2013 11:26 am by Kamen Nikolov | Last modified 3/22/2013 12:46 pm by Jason Byrnes | 1620 views | 3 replies |
Kamen Nikolov
I have created product pages with Data Bridge and they work great. One small glitch on admin/products_insert.php and admin/products_udate.php the I have two upload boxes one for ProductThumb and one for ProductImage respectively setup in the dB as _images/products_t/someimage_t.jpg and _images/products/someimage.jpg.
In the Shopping Cart this setup and everything is working fine, but if I try to go and insert or update product and I set the path to upload correctly the entry in the dB instated of being _images/products_t/someimage_t.jpg and _images/products/someimage.jpg. is just someimage_t.jpg and someimage.jpg which doesn’t display the images in the Shopping Cart and PrductDetails.
Here is the setup now:
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../_images/products_t",
'FileName' => "[FileName]",
'DefaultFileName' => "".($row_WADAproducts["ProductThumb"]) ."",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
// WA_UploadResult2 Params Start
$WA_UploadResult2_Params = array();
// WA_UploadResult2_1 Start
$WA_UploadResult2_Params["WA_UploadResult2_1"] = array(
'UploadFolder' => "../_images/products",
'DefaultFileName' => "".($row_WADAproducts["ProductImage"]) ."",
// WA_UploadResult2_1 End
// WA_UploadResult2 Params End
Any help will be appreciate.
Kamen
Only the file name should be stored in the database. not the path.
the path should be added to the src attribute of the image tab on the page that displays the images
<img  src="path/to/images/<?php echo($row_recordsetName['imagecolumn']); ?> />
Kamen Nikolov
Thank you Jason,
Is that set up in the fileUpload behavior?
no, it is set up in the image tag.
