Search option
Thread begun 3/22/2013 7:52 am by wbrooks199805 | Last modified 3/22/2013 9:02 am by wbrooks199805 | 2517 views | 4 replies |
wbrooks199805
Search option
I am trying to update up DA search and it keeps generating code <?php require_once("../webassist/database_management/wada_search.php"); ?> which gives an error:
Fatal error: Cannot redeclare waqb_getenddate() (previously declared in /home/content/n/a/m/namcnational/html/webassist/database_management/wada_search.php:332) in /home/content/n/a/m/namcnational/html/WADbSearch/HelperPHP.php on line 345
So I delete that ..but it won't return any search options.
I have attached the file.
I did up date recently from Data Assist to Data Bridge. Also, All the records show when I open the page. As soon as I do a search all the records disappear. I want to be able to search by each field, not all. I think I have the correct as "AND"
You need to remove line 9 which is the include for the old Data Assist search include file:
<?php require_once("../WADbSearch/HelperPHP.php");?>
to troubleshot why the search is not returning any results I will need a link to the search page to test the search.
also if you could add the following code on the results page just after the <body> tag to display the search SQL, that would be helpfull:
<?php echo("SQL: ".$query_limit_WADAmembers."<br />"); ?>
wbrooks199805
here you go..
members_Results.php
one issue I see is in the last 2 select lists, they do not have blank values for the default options. in the sourch code i see:
<select name="S_servicesone" class="WADADataTableCell" id="S_servicesone">
<option selected>NACIS Code</option>
and:
<select name="S_divisionone" id="S_divisionone">
<option value="selected" selected="selected" > Divisions</option>
those should be:
<option value="" selected>NACIS Code</option>
and:
<option value="" selected="selected" > Divisions</option>
wbrooks199805
You are right
When I put that code on, I thought it might be that.
Thanks so much Jason, as always. ;)
