Form Problem
Thread begun 3/21/2013 11:09 am by gary917 | Last modified 3/21/2013 11:23 am by Jason Byrnes | 1015 views | 1 replies |
gary917
Form Problem
Hi I have a form using the following for the button...
<input class="formButton" name="Appointment_submit" type="submit" value="Send Message" id="Appointment_submit" onclick="clearAllServerErrors('Appointment_Hornet_Default')" tabindex="10" />
instead of...
<input class="formButton" name="Appointment_submit" type="image" value="Send Message" id="Appointment_submit" src="webassist/forms/fd_hornet_default/btn_submit.gif" onclick="clearAllServerErrors('Appointment_Hornet_Default')" tabindex="10" />
I am using CSS to display the image for the button. However, when I change the type="image" to type="submit" causes a problem with the captcha code. If any value is added to the captcha code field the form executes and the form is sent. The checking for like values seem to ignored.
Can you explain why this is happening.
this is because of the trigger used for the validation.
when you change the input from type="submit" to type ="image" you need to edit the server validation behavior to have the trigger code regenerated.
with the submit element type, there is a value attribute, so the trigger code will look like this:
if (isset($_POST["Appointment_submit"])) {
an image element though, does not include a value attribute, it cannot pass a value, it does pass x and y coordinates of where it was clicked though, so the trigger code for an image element would look like this:
if (isset($_POST["Appointment_submit_x"])) {
if you change the submit element type, you will need to edit the server validation behavior to have the code regenerated.
