Building Form. Keep getting and error and Dreamweaver crashes
Thread begun 3/20/2013 2:41 pm by frank375703 | Last modified 9/09/2013 1:40 pm by Jason Byrnes | 13141 views | 51 replies |
frank375703
I am building a form to place in a website and I have done it in 2 parts. First I created the form and edited all the fields. then I hit "finish". the form exists in my webpage. Then i went back in to edit the design. I went through all the options and then hit "finish" and get an error. the error reads:
"While executing onMouseDown in WAFB_AddForm.htm, the following Javascript error(s) occurred:
At line 4179 of file "Belial:Library:Application Support:Adobe:Dreamweaver CS6:en_US:Configuration:Shared:WebAssist:Services:fb_shared_functions.js":DWfile.getAttributes(orig) has no properties
Then Dreamweaver crashes and I lose all my formatting. I have redone this a few times, wasted a lot of time and energy and am getting no where. My client is breathing down my throat and I don't understand why this is happening. Earlier this week i created a test version and did the whole process and got my form results and felt pretty confident that when I had to make the actual form for my client it was go very easily.
I researched your forum and the only advice I saw was to go to Window > Work Space Layout > Reset (showthread.php?t=29781). I then had to reactive Data Bridge and then I get the same results. What am I doing wrong? I bought these extensions to make my life easier and have this go quickly, yet here I am stalled and frustrated.
as you can see from this link, the form is in my page but default formatting is applied. appointments.php
Please help.
frank375703
here is line 4179 if (DWfile.getAttributes(orig).indexOf("D") >= 0) {
here is an updated copy of the Configuration:Shared:WebAssist:Services: fb_shared_functions.js file that should correct the error
frank375703
Hi Jason, I didnt see any attached file with your post. where do i download it?
My Applogies, it should be attached to my reply now.
frank375703
Thank you! One more question. Where do I put the file? When I search my iMac, there isnt any file path like that.
see this tutorial for details on locating the users configuration folder:
http://www.webassist.com/community/tutorials/view_tutorial.php?tid=95
the file goes in Configuration:Shared:WebAssist:Services: fb_shared_functions.js
frank375703
On new mac mini, again having issues
i getting this error message
"While executing onChange in WAFB_AddForm.htm, the following Javascript error(s) occurred:
At line 4179 of file "Belial:Library:Application Support:Adobe:Dreamweaver CS6:en_US:Configuration:Shared:WebAssist:Services:fb_shared_functions.js":DWfile.getAttributes(orig) has no properties".
Additionally i cant see a preview of my form and im getting a message that says
"Error generating preview: TypeError: DWfile.getAttributes(orig) has no properties"
I have already reset my layout, deleted the macdata file and restarted dreamweaver.
have you installed the updated the fb_shared_functions.zip file from message 5?
frank375703
yes. did that too. and now when i try and update the form, it eliminates all web contents except for the form itself.
