Repeat Selection For All Records
Thread begun 3/19/2013 12:16 pm by Cologne | Last modified 3/20/2013 10:52 am by Jason Byrnes | 2490 views | 5 replies |
Cologne
When I choose ALL records in the Repeat Selection it shows the alternativ (else) text, too.
What was the trick. I know that there was a trick.
// RepeatSelectionCounter_1 Initialization
$RepeatSelectionCounter_1 = 0;
$RepeatSelectionCounterBasedLooping_1 = false;
$RepeatSelectionCounter_1_Iterations = "-1";
<head>
<title>Unbenanntes Dokument</title>
</head>
<body>
<form id="formBandGenre" name="formBandGenre" method="post">
// RepeatSelectionCounter_1 Begin Loop
$RepeatSelectionCounter_1_IterationsRemaining = $RepeatSelectionCounter_1_Iterations;
while($RepeatSelectionCounter_1_IterationsRemaining--){
if($RepeatSelectionCounterBasedLooping_1 || $row_allGenre){
<input type="hidden" name="WADA_RepeatID_id_<?php echo $RepeatSelectionCounter_1; ?>" id="WADA_RepeatID_id_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_allGenre["id"]; ?>" />
<input <?php if (!(strcmp($row_allGenre['id'],WA_AB_returnPreSelectValue($WA_PreSelect_RelationalTable_1, $row_allGenre['id'])))) {echo "checked=\"checked\"";} ?> name="genre_<?php echo $RepeatSelectionCounter_1; ?>" type="checkbox" id="genre_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_allGenre['id']; ?>" />
<?php echo $row_allGenre['genre']; ?><br />
} // RepeatSelectionCounter_1 Begin Alternate Content
else{
nix
<?php } // RepeatSelectionCounter_1 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_1 && $RepeatSelectionCounter_1_IterationsRemaining != 0){
if(!$row_allGenre && $RepeatSelectionCounter_1_Iterations == -1){$RepeatSelectionCounter_1_IterationsRemaining = 0;}
$row_allGenre = mysql_fetch_assoc($allGenre);
$RepeatSelectionCounter_1++;
} // RepeatSelectionCounter_1 End Loop
<input type="submit" name="button" id="button" value="Senden" />
</form>
</body>
Cheers,
Denis
set the alternate content to a non breaking space:
&nbsp;
Cologne
lol :-)
no, this is not the right way :-) I remember it was something to change the code with TRUE.
If this is an error, can it be fixed in an update?
Cheers,
Denis
change this part of the code:
    else{
    else if ($RepeatSelectionCounterBasedLooping_1) {
Cologne
Thank you :-)
Will this be fixed in an update?
Yes, i have logged this in our bug base to be corrected in a future update.
