Help with colour options
Thread begun 8/12/2009 7:30 am by Suggs | Last modified 8/12/2009 1:19 pm by Jason Byrnes | 1529 views | 1 replies |
Suggs
Hi Folks,
Im wanting to bring across colour options from my add to cart button so they display in the basket.
The colour options are already populated from the database and each colour option in the list has its own add to cart button.
Can you advise how I can best achieve this
Best Regards
Paul
You need to have a column in your cart object to for the color option. you will likely want to set the column to be unique.
In the add to cart button, select the new color cart column, and set it to be update able from a hidden form field.
this will add a hidden form field to the add to cart button form, set the value of the hidden form field to come from the recordset.
When you create the cart display page, make sure you select the color column on the second step of the display wizard so it will show when the item is added to the cart.
