Ecart Database Connection Error
I am testing ecart on my local machine. I am using the online tutorial as a guide. I am using the checkout wizard. I came to the page Store Order Summary in Database. I checked the box Create Using Preset and chose the Default Preset.
I am required to create a connection. So I went to phpmyadmin and created a database. The database was created but neither tables or fields were added as I read on the tutorial that "eCart 5 will automatically create the necessary tables in your database, and bind the appropriate data."
I made a connection to the newly created database, tested it and received the message that connection was successful. I then clicked next and received the message, "Please select a valid connection to continue". What could be the reason for this message when in the step prior, I am told that the connection to the database is successful?
Tried that. Also tried the option that requires me to select the db table and bind the values (which it recognizes) and then switching back. No luck.
