Error message when database tables are created on registration form
Thread begun 3/18/2013 2:42 pm by info396563 | Last modified 3/27/2013 12:01 pm by Jason Byrnes | 5203 views | 16 replies |
info396563
Hi Jason
I am getting an error message when I go through the steps to create the database tables for the login registration form:
'We tried to create your database table for you, but were unsuccessful. The CREATE TABLE statement has been stored in a sql file located at: path to file....'
Can you confirm what I need to do to stop this and have Databridge create the tables automatically please.
Scott
double check the site definition settings for connecting to the testing server to ensure they are correct. It is the testing server settings that at the the heart of connecting to the database.
info396563
When I carry out a test in the site definition dialog box it connects successfully!!!
Is the URL PRefix correct for the site?
Are you using FTP to connect to the testing server?
if your using FTP and testing the connection, that only means that the FTP Host, User Name and Password are correct.
do you have the correct host directory entered?
info396563
Can you confirm what this should look like as it looks fine to me but I don't know what else I should be looking for.
Is the URL PRefix correct for the site? - YES
Are you using FTP to connect to the testing server? - YES
do you have the correct host directory entered? - THIS IS CURRENTLY public_html/
It's imposible for me to know what your site settings should be without knowing the site configuration. Site settings are unique to the site.
what specifically is the URL Prefix you entered?
the hist directory should normally have a leading slash in it:
/public_html/
info396563
Ok please see info below:
Is the URL PRefix correct for the site? - YES - www.pixalart.co.uk/
do you have the correct host directory entered? - THIS IS CURRENTLY /public_html/
info396563
Ok I have imported the SQL file into PHP MyAdmin and it looks ok, the issue I have now is I'm trying to set the session variables, and when I add the 'Recordset: rsVerify is not empty' it does not pull up the emailVerified session. For some reason this does not appear in the Sessions but it does in the Recordset RSVerify.
(This is at 23.08 on your youtube tutorial)
Not sure where its gone wrong but can you confirm how I can correct this?
you may need to create the binding manually.
open the bindings panel and click the plus button, select Session, then name the session binding "emailVerified"
info396563
Ok..I think this is going to be a long post...
have completed the tutorial and tried to test the pages. I completed the registration page and got the following error:
Warning: require(Blank_2.php) [function.require]: failed to open stream: No such file or directory in /home/pixalart/public_html/webassist/email/mailformatting_php.php on line 151
Fatal error: require() [function.require]: Failed opening required 'Blank_2.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/pixalart/public_html/webassist/email/mailformatting_php.php on line 151
