Multi select update
Thread begun 3/18/2013 4:26 am by chris250441 | Last modified 3/18/2013 8:44 am by chris250441 | 2001 views | 4 replies |
chris250441
Multi select update
I have placed the following code at line 1:
if($_SERVER["REQUEST_METHOD"] == "POST") {
foreach($_POST as $key => $val) {
if(is_array($_POST[$key])) $_POST[$key] = implode(", ", $_POST[$key]);
and have the following multi select:
<select class="formListfield_Medium" name="User_Update_group_1_ExpertiseAreas[]" id="User_Update_group_1_ExpertiseAreas" tabindex="19" multiple="multiple">
<option value="">Please select your expertise areas </option>
do {
<option value="<?php echo $row_rsExpertise['ExpertiseField']?>"><?php echo $row_rsExpertise['ExpertiseField']?></option>
} while ($row_rsExpertise = mysql_fetch_assoc($rsExpertise));
$rows = mysql_num_rows($rsExpertise);
if($rows > 0) {
mysql_data_seek($rsExpertise, 0);
$row_rsExpertise = mysql_fetch_assoc($rsExpertise);
</select>
The problem I have is that lose previously stored selects when I try and update. What would I need to change so it holds previously selected multi items?
Many thanks
I think the real problem is the database design.
You shouldn't be storing a comma separated list of values in a column of your table. this is a bad database design.
instead you should be using a linking table and use the Data Assist Manage relational table behavior.
There is a tutorial for this on the data bridge support page:
data-bridge/
chris250441
Thanks Jason, I am stuck with what I have got so can you help me or not?
It requires hand coding to accomplish.
see this post:
showpost.php?p=121667&postcount=2
chris250441
Halleluiah!!! it's like squeezing blood out of a stone. Thanks Jason.
