Change static themes by dropdown
Thread begun 3/17/2013 4:27 pm by neo314 | Last modified 3/18/2013 9:37 am by neo314 | 1560 views | 2 replies |
neo314
Once I am in a Framework Builder Static theme, why, in order to change theme, do I have to:
  1. Remove the behavior.
  2. Apply the other template.
  3. Apply the theme.
Maybe there is a reason, but if I can have dynamic themes, why can't I open the static theme behavior and choose from the available themes.
I am changing the static theme on a web site and that is how this came to mind.
Thanx,
Steven
a static theme allows you to apply only one theme.
a dynamic theme allows you to apply multiple themes and have a variable determine at run time which one to use. They are completely different.
a static theme is intended to be applied once and not changed. In order to change the theme, the previous theme must be removed first.
neo314
Well, if I might suggest, a dynamic theme means it can be changed by a variable. A static theme means that it cannot be changed by a variable. Neither means the theme will never change, or even that it might not change fairly often.
It is not a big deal, and perhaps there is a reason, but I'm not sure why it takes several steps instead of one.
